master cylinder question
Old Mar 21, 2006 | 01:04 PM
mikewho's Avatar
mikewho
Navigator
Default master cylinder question
Found small leak coming from m/c. I have new m/c here but it did not come rear foam seal. Parts guys didn't know anything about it. Do I need this seal?
Mikewho
Old Mar 21, 2006 | 02:03 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Mikewho
???????? My new MC had no foam seal. Are you referrring to a seal between the MC & booster?
Old Mar 21, 2006 | 02:11 PM
mikewho's Avatar
mikewho
Navigator
Yes. I've seen this part on web sites for m/c. components. You didn't replace your m/c with seal? Any leaks?
Old Mar 21, 2006 | 07:58 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
if your master cylinder is leaking out the back it is in need of repair...
Old Mar 21, 2006 | 10:56 PM
ratflinger's Avatar
ratflinger
That's what I was thinking, their should be no fluid anywhere, except inside. I haven't installed the new one yet, as I just got the parts for the hydroboost hoses, but the old one came off w/o any foam seals.
To master cylinder question
