Carb help
Old Mar 21, 2006 | 08:32 PM
76project's Avatar
76project
Default Carb help
I am amazed, I rebuilt my carb myself and the car started right up. My son (a diehard mopar fan) was helping me tune the carb, it is a stock Rochester on my 76 L48. He said it seems like it has a vacuum leak because we could not get it to idle below 700 and if you put your hands over the top of the carb it doesn't kill the engine. It did slow it down some but not to the point of killing the engine.
I am still trying to figure this stuff out but he asked me (and thats why I am asking you all) about the secondaries, if you look down the body, should the secondaries be pretty level with the base plate or are they on a slight angle when closed. He thought they were not closing completely. I don't see a gap but he thought they should be flat. We did have a vacuum gauge hooked to the port that goes to the air cleaner and it was holding very steady when the car was running. I am still pumped that it started, can't wait to drive her. A couple more things before road ready. Thanks for your help.
Old Mar 21, 2006 | 10:30 PM
dgruenke's Avatar
dgruenke
You can take a can of carb cleaner and spray certain areas of the carb and see if you get an engine reaction (revving up or bogging down). This will tell you if you have a leak. Sometimes the Q-jets develop a vacuum leak on the rod that runs through the bottom throttle body plate. I believe this is the same rod that the throttle linkage is attached to. The bushings can be replaced, but I recommend a shop do that work.
Old Mar 21, 2006 | 10:33 PM
73 LS-4's Avatar
73 LS-4
If you have some carb cleaner available spray it around the base plate and throttle shafts and see if the idle picks up. A lot of these old quadrajets with high miles tend to have vacuum leaks around the throttle shafts. As far as the secondary throttle shafts not being level, that's normal, they should be at a slightly higher angle then the primary throttle plates.
Pat Kunz
Old Mar 22, 2006 | 08:32 PM
unclesly's Avatar
unclesly
Is the throttle cable attached? If so, unattach it and see. Mine was idling fast, and I tried to figure it out. The cable broke off, and the idling went back to normal. The cable was kinked through the firewall. The lever point had to be adjusted by 1/4"
S
Old Mar 23, 2006 | 08:59 PM
fritz76's Avatar
fritz76
Default Brake booster
I had the same problem and it turned out I was sucking air through the brake booster. Pinch the rubber hose going to the booster and see if the idle changes.
Old Mar 24, 2006 | 07:36 AM
76project's Avatar
76project
I will try that, I also know my headlight actuators leak, I will try to close off most extra vacuum. Someone at work thought maybe having the float too high would cause the same sympton but if you cut off the air it seems like it would still die.
Old Mar 24, 2006 | 10:48 AM
kevinator80's Avatar
kevinator80
Cupping your hands over the carb is a test for a lean condition, which will cause a high idle. If you have a leak it could cause a lean condition so eliminate that possibility. After that, you may want to richen up with the mixture screws.
Old Mar 24, 2006 | 05:11 PM
76project's Avatar
76project
If the float was off would that also cause a high idle? I did adjust it per the directions.
Old Mar 24, 2006 | 05:28 PM
comp's Avatar
comp
Old Mar 24, 2006 | 08:51 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
I worked for 2 weeks looking for a leak ... turned out to be the rear seal on the brake booster. Engine would accelerate by 100 rpm when you pressed the brake at idle.
Replaced the booster....ran like new.
Old Mar 24, 2006 | 09:58 PM
kevinator80
I suppose with the float too low you could get a lean condition. I am basing this on my demon experience, mine was way rich with the float at the top line in the site glass. I can't remember what Lars' paper suggests as float height on a qjet.
Old Mar 25, 2006 | 07:50 PM
76project's Avatar
76project
I think I am going to plug all vacuum ports that aren't needed to Idle and see if that makes a difference.
To Carb help
