Rear support braces..
Old Mar 21, 2006 | 09:02 PM
DOUG OLAH's Avatar
DOUG OLAH
Default Rear support braces..
Hi- I have a 68 BB convertable and I would like to know if adding the rear support braces on the rear crossmember to the axle Kick-up area
(I believe after the 68 model year they added them to 69 and later vehicles) would it add much strength by welding these on?? thanks
Old Mar 21, 2006 | 09:08 PM
big_G's Avatar
big_G
If you had the body off, I would certainly add them. It is a known weak area on 63 to early 68's...
Old Mar 21, 2006 | 09:25 PM
DOUG OLAH's Avatar
DOUG OLAH
thanks --I do have the body off .Any other tips to add strength to the
rear area?
Old Mar 21, 2006 | 10:10 PM
TCracingCA's Avatar
TCracingCA
Default Be careful!
We have both a 1964 and a 1968, and have a 1972 and the 1964 through the 1967 adding those would interfere with the body. I am looking at the 1968 and there might be a problem there also. It is hard to see with the body on. Suggest taking measurements. Would hate to hear that you are trying to drop it back down to the frame and something is getting in the way. The 1968 had alot of carry over from the 1967 year. You may have to cut for clearance on the glass if you do that (add those braces). Also since this was a transitional year, an early car like ours may be different than a late car. I bought some of these braces to do this for the 1964 (race car). The 1968 is primarily a street car, therefore not so stressed. Instead I put the rollcage back into the car to triangleate (pardon my spelling I am typing fast) this area. If the frame isn't rotted, then for street you should be ok. It doesn't sound like you are after pure stock concourse restoration, if you need the strength bring a bar down from the upper portion of that rear kickup area and tie down to the frame rail. This also makes for a great bit of added protection to you sitting in that seat from a side impact.
Old Mar 21, 2006 | 10:20 PM
big_G's Avatar
big_G
I added them to a '68, the frame didn't have them...No interference at all...but check your body to be sure. I think you can buy the braces, you may tack them in place and do a trial fit.
P.S. Both of my '68's have them. (From the factory). Both about S.N. 15,000
Old Mar 21, 2006 | 10:24 PM
DOUG OLAH's Avatar
DOUG OLAH
thanks for the information. I thought their might be interference. I asked the guy where I bought these and he said shouldn't be a problem. I'll take some mearurements soon.
To Rear support braces..
