Machining Question
Old Mar 22, 2006 | 01:06 PM
ddn's Avatar
ddn
Default Machining Question
Hey guys, long time no see. College is over, and its time to get back to work on the Corvette.
My big block has been sitting far too long since the machine work was done without getting built. I just have one problem before I can build it.
I need to have the pistons machined for valve clearance. Mocking the engine up would be a little complicated, and what I'd like to do is just cut the pistons for something near the max allowable. Is this reasonable?
Pistons are TRW/Speed-Pro 2465's and the heads are 071 open chamber castings.
Can anyone recommend a machine shop in the Twin Cities area? What exactly do I have to tell them so they know where to relieve the pistons?
Thanks for the help everyone.
Old Mar 22, 2006 | 05:45 PM
Tonys96's Avatar
Tonys96
MAS in Ellsworth WI.
Phone number 715-273-5027
Talk to Mike or John
Just tell them what parts you have and what you plan to do.
Great shop, great guys, far enough away from the Twin Cities to give great service at a reasonable price, just across the river from Red Wing.
Old Mar 22, 2006 | 06:52 PM
Gordonm's Avatar
Gordonm
You may be going through a lot of work for nothing. Unless you are running a very high lift cam chances are you have plenty of clearance. What is your intended lift of the cam? A mockup is not thatdifficult and can tell a lot. I just use 1 piston without rings on it and assemble 1 head with only 1 set of valve springs.
Old Mar 22, 2006 | 11:32 PM
ddn's Avatar
ddn
Last time I mocked it up (a couple years ago) I couldn't get a full crankshaft rotation, as the piston was hitting (something). Now I'd rather just relieve them and get on with the show.
Old Mar 23, 2006 | 06:12 AM
VintageMuscle's Avatar
VintageMuscle
Hi lift is related, but it's really dependent on how quick the valves come off the seat. Solid Rollers are the quickest, hydraulic rollers and solid flat tappets are next, and hydraulic flat tappet are the slowest (normally).
To Machining Question
