TOO HOT...
Old Aug 26, 2001 | 11:11 AM
8T1-7T9 BIONIC VETTE's Avatar
Default Re: TOO HOT... (Chuck H.)
Looked behind right kick panel and found vent door wide open.....removed the vacuum assembly, slammed the door shut.....filled void with foam,.....and sealed that sucker up.....test ride was much better....still some heat coming in around the gas pedal, however I think this is coming from under the center consel,.....is the center consel hard to pull? :confused:
