Carb tuning / Timing issues???
Old Apr 4, 2006 | 11:28 AM
hotwater's Avatar
hotwater
Default Carb tuning / Timing issues???
Okay, have a 76 with the L48. I recently changed out some stuff and the car is driving me nuts. Here is the list of mods:
Holley Street dominator aluminum intake manifold
Holley 600 CFM carb
Accell Distributor, Cap and rotor
Accell high output coil
Mid America True Dual Kit and Flowmasters
I finally got the carb to where it seemed to be doing really good. Had great throttle response, decent on the upper end as well. This morning after taking the slow drive home from work, it backfired and died on me while pulling into the driveway. Idle in Park or Neutral is about 700 rpm and in gear, it is about 500 rpm. At times if you hit the gas too hard from a stop, it will stumble really hard. Other times, it will go without missing a beat. When driving, sometimes if I do a heavy take off, it will try to die on me like it is starving for fuel. have a brand new mechanical pump and new fuel filter on there. I am going to try to mess with the timing some more today. Does this sound like a timing issue or more like a carb issue? Any help at all will be apprecated. I am leavng for the sand box soon and just wat to be able to enjoy my Baby for a little while before I go.
Thanks,
Glen.....
Old Apr 4, 2006 | 02:46 PM
hotwater's Avatar
hotwater
Anyone?????
Old Apr 4, 2006 | 02:57 PM
KMB's Avatar
KMB
Sounds like a carb issue to me. I had similar issues until I had my carb rebuilt. The choke was the main culprit.
What is your timing set to? Does it wander at idle, or stay where it's supposed to be?
Old Apr 4, 2006 | 02:58 PM
comp's Avatar
comp
Old Apr 4, 2006 | 03:12 PM
a1sensei's Avatar
a1sensei
Sound like typical Holley / Accell issues to me, I usually avoid them. Last Holley product I bought was defective, and as the dealer and I tried to explain the problem to one of their tech guys, he told me "The product is fine, I guess we just don't make things for YOUR car." I took that statement to heart. Sensei
hotwater's Avatar
hotwater
The carb s brand new, out of the box. So if it needs to be rebult, it's going back. As far as timing, it is set at 7 degrees BTDC at idle. Stll tryng to understand the concept of the "total" timing. The engine is not wandering at idle at all. Smooth idle and the tach sits pretty steady.
Old Apr 4, 2006 | 04:31 PM
Higs's Avatar
Higs
7 seems low to me on idle. Mine took 15 but I removed vacum advance.
Old Apr 4, 2006 | 04:41 PM
MsVetteMan's Avatar
MsVetteMan
7???
Man....wind that toy up!! Get that thing up to a least 12 and try her out. You could probably get even more out of her. Listen carefully to your engine for pings/knocks from running to much timing however. If you hear any pinging, knock it back a couple of degrees, and try again.
Read Lars paper to fine tune it, but for starters, advance that timing!! https://www.corvetteforum.com/techti...=109&TopicID=3
Old Apr 4, 2006 | 04:55 PM
hotwater's Avatar
hotwater
Originally Posted by MsVetteMan
7???
Should that be 12 before or after TDC? This timing stuff is fairly new to me. Sorry.
Old Apr 4, 2006 | 05:08 PM
KMB's Avatar
KMB
I'm not sure of the factory specs for your year, but my '73 is set at 12* BTDC.
that you need to time it correctly before messing around with the carb.
Old Apr 4, 2006 | 05:19 PM
MsVetteMan's Avatar
MsVetteMan
Before, and without vac advance hooked up. Setting timing a idle is just a basic quick way to get you in the ball park and running okay.
What you will want to do after is check to make sure you are getting 36* of timing all in before 3000 rpm. If you are not, you will need to change to some softer springs in the distributor. But for now, adjust your idle timing for 12 to 15* BTDC. After you get it set, tighten down the distributor, hook up the vac, and set your idle rpm between 800 and 900 rpm with the idle adjustment screw. You have to play with that a little. Some cars want more, and some less.
See what kind of difference it makes, but listen carefully for pinging or knocking.
hotwater's Avatar
hotwater
According to the chilton manual, it says 6 degrees BTDC.
Old Apr 4, 2006 | 05:27 PM
MsVetteMan's Avatar
MsVetteMan
Lars, or Chilton? Trust us.......
Chilton is for a stock setup and strictly for economy, and is very conservative. You won't hurt anything, just start a 10 if that makes you feel better, and then work your way up.
Old Apr 4, 2006 | 05:29 PM
hotwater's Avatar
hotwater
BTDC right?
Old Apr 4, 2006 | 05:31 PM
MsVetteMan's Avatar
MsVetteMan
Yep.......
^^^^^^^^^^^^taking advice from a man who blew his motor up last week
Old Apr 4, 2006 | 05:34 PM
hotwater's Avatar
hotwater
Yep.......
OUCH!!!
I will give it a try. I trust you guys more than the chilton manual when it comes to the performance related stuff. How far up will the factory timing tab go to?
Old Apr 4, 2006 | 05:37 PM
MsVetteMan's Avatar
MsVetteMan
You do have a timing light, right?
Easiest way to do it is loosen the distrib. bolt (not to loose), crank her up, unplug vac at carb (you may have to raise the idle at this point), and start nudging the distrib. counter clockwise a little at a time, then checking timing light, and so on. Just work slowly. A little turn means a lot, so don't get carried away. You can tell by ear how it's doing as you turn the distributor. Take it up to 12 and test drive. You can readjust if necessary.
DO NOT ADVANCE IT TO MUCH!! BACK IT DOWN IF YOU HEAR ANYTHING FUNNY. TEST DRIVE IT AND MAKE SURE IT'S NOT PINGING. RUNNING TO MUCH ADVANCED TIMING CAN CAUSE YOU TO OVERHEAT, or Worse.
There, I feel better now.
Take the time to read some articles of setting timing. (google). Buy a spring set for your distrib. and nail it later!!
To Carb tuning / Timing issues???
Old Apr 4, 2006 | 05:41 PM
hotwater's Avatar
hotwater
Okay, I'm gonna go give it a shot. I'll let you know what I come up with. Thanks.
Old Apr 4, 2006 | 05:43 PM
MsVetteMan's Avatar
MsVetteMan
<<<<--------------<< Praying Hotwater doesn't blow up his motor.
Old Apr 4, 2006 | 05:56 PM
Kalway's Avatar
Kalway
Yep.......
I still have a hard time believing detonation caused it.
