Run stand wiring hookup..help
Old Aug 18, 2001 | 03:25 AM
LT1driver's Avatar
LT1driver
Default Run stand wiring hookup..help
OK, I am ready to run by big block on the run stand I made. How do I hook up wiring to dist, battery, etc. so I can start it and run it for break in. Any help will be greatly appreciated. Thanks. :chevy
Old Aug 18, 2001 | 04:13 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Run stand wiring hookup..help (LT1driver)
you want to wire a direct hot to from the battery to the post on the starter, and then over to the alternator.
Wire a 12 V+ through a switch to the distributor, so you can turn the spark on and off.
A push button for the starter.
Ground wire from a bellhousing bolt should work, or any bolt for that matter.
The biggies are full 12 V+ to the starter, button controlled starter and switch controlled ignition.
And make sure that stand is not going to go anywhere --- these motors move around more than you think !!
Old Aug 18, 2001 | 04:20 AM
LT1driver's Avatar
LT1driver
Default Re: Run stand wiring hookup..help (BSeery)
Thanks, I will try and set it up tomorrow. The stand base is pretty big and heavy 1-1/2 box with 1/8 thick. Thanks again.
Old Aug 18, 2001 | 04:22 AM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
what are you doing for fuel and cooling ?
Old Aug 20, 2001 | 03:13 AM
LT1driver's Avatar
LT1driver
I am hooking up the rad in front with some wood stands and for fuel I am running line to gas can, using mech pump on engine. Hope all works. :yesnod:
To Run stand wiring hookup..help
