G=tech any good
You will need to know the weight of your car at the time you are running for full accuracy.
http://www.gtechpro.com/how.html
I thought you were going to sell it -- I am interested in buying !!
[Modified by BSeery, 12:10 AM 8/20/2001]
"G-TECH/Pro takes advantage of many different measurements that can be gathered from acceleration over time. For Horsepower measurement the user has to input the weight of the vehicle. We utilize what we call "Intuitive User Interface". To input weight all you have to do is simply tilt G-TECH/Pro up and the numbers will increase and if you tilt it down the numbers will decrease. Further you tilt it faster the numbers change.
In Horsepower mode G-TECH/Pro will display currently delivered horsepower during acceleration and then when you slow down it will display maximum delivered horsepower.
All the measurements are performed automatically. All you have to do is push the button indicating to G-TECH/Pro that you are ready and then G-TECH/Pro will zero-out and display -GO-. Then simply start accelerating. G-TECH/Pro will know your speed and distance at any given moment and stop the measurement at 60 mph or 1/4 mile point.
While measuring Lateral or Longitudinal G's user has the choice of Instantaneous or Continuous mode. Instantaneous G's are great for analyzing when tires lost traction during braking and cornering or measuring any other kind of G-load. Continuous G's are designed for standard Skidpad handling measurements of Lateral G's.
When measuring Braking distance in feet user doesn't have to start braking exactly at 60 mph. G-TECH/Pro knows the speed always and it will only measure distance from 60-0 mph even if you started braking at 65 mph for example.
