need your help
Old Apr 8, 2006 | 03:10 PM
RPOL36's Avatar
RPOL36
Default need your help
I put aluminum foil balled up in the holes to protect them while I painted my heads well when I went to get one of the balled up aluminum foils out it fell down into the hole in the head I am showing above.(the big hole shown)
I saw it at first in there and tried with tweasers but that pushed it out of site.
then I tried my shop vac with tubing attached at the end.
then some odd tools wrapped in duct tape to try to grab onto it and pull it out.
no luck yet. any ideas? please help
Old Apr 8, 2006 | 03:11 PM
RPOL36's Avatar
RPOL36
n/a
Old Apr 8, 2006 | 03:14 PM
LittleJake's Avatar
LittleJake
Do you know your double posting the same thread in the tech and general section? Are you doing that or is there a glitch?
Old Apr 8, 2006 | 03:46 PM
RPOL36's Avatar
RPOL36
Hey, what about the big plugs on each end of the heads...........can I take both of those out shoot air in one end and maybe it will come out the other end?
that is if it is all connected in there.
Old Apr 8, 2006 | 05:20 PM
RPOL36's Avatar
RPOL36
someone should know if taking those end caps off should work or not..want to know before I take them off
Old Apr 8, 2006 | 05:23 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I'm not sure what the hole in question is for, but have you tried just blowing compressed air into it?
Old Apr 8, 2006 | 05:39 PM
RPOL36's Avatar
RPOL36
blow air into the hole that it fell into? that would just push it somewhere futher away.
OR do you mean blow compressed air into the ends of the head via the two end caps? that is what I am thinking of doing is removing those two end caps and blowing air through it maybe it will come out the other end. is that what your suggesting?
thanks
Old Apr 8, 2006 | 07:55 PM
RPOL36's Avatar
RPOL36
i give up, hope it don't hurt anything
Old Apr 8, 2006 | 08:15 PM
GUSTO14's Avatar
GUSTO14
Have you tried one of these?
They're available at any good auto parts store... or you can get this one from Snap-On...
http://buy1.snapon.com/catalog/item....re&dir=catalog
Good luck, I definitely would not leave it in there... GUSTO
Old Apr 8, 2006 | 08:25 PM
rcread's Avatar
rcread
Listen to Gusto, do NOT leave that foil in there. I've never heard of using aluminum foil to mask. They have this tape you can use for that purpose. Hmm, what do they call it? Oh yeah, masking tape. You might want to pick some up for your next painting project. The heads do look good though.
To need your help
