1981 Vette Choke Light
Old Apr 11, 2006 | 11:18 PM
ckaprolet's Avatar
ckaprolet
Default 1981 Vette Choke Light
This light has decided to come on and stay on...any ideas appreciated. Had been fine. Shop manual section on this is over my head.....
any help appreciated...
Old Apr 12, 2006 | 12:02 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
This post might help you
http://forums.corvetteforum.com/showthread.php?t=222539
Old Apr 12, 2006 | 11:35 AM
stickboy's Avatar
stickboy
Originally Posted by Glass Act
use the search function, make sure you check the archives box. This subject has been discussed many times, most likely your problem is a wiring short or a bad choke heater relay.
Old Apr 13, 2006 | 07:15 AM
ckaprolet's Avatar
ckaprolet
Will do some searching. Thanks. Seems to be many possibilities.
To 1981 Vette Choke Light
