Attn. Lars
Old Apr 19, 2006 | 01:00 PM
big_G's Avatar
big_G
Default Attn. Lars
I have a 454 in the shop with a Q-Jet #7040502 (original to a 70 350-300). What the problem is I can't get the idle mixture rich enough. Any suggestions? No apparent vacuum leaks.
Old Apr 19, 2006 | 01:08 PM
lars's Avatar
lars
The following items will affect idle lean condition:
Vacuum leak
Incorrect jets and/or rods
Low float
Low set power piston height (or piston modified by cutting tang)
Warped airhorn (leaking air into transfer passages)
Incorrect base gasket
Incorrect throttle plate gasket
Altered idle air bleed system (common on commecial rebuilt carbs)
Secondary throttle plates not fully closed
Let me know if you need more ideas.
Lars
Old Apr 19, 2006 | 01:42 PM
1978 mayhem's Avatar
1978 mayhem
From: Bedford Iowa, i didn't know spending this much money could be so fun!!
hey las it true u cant get in any carbs untill next year?
Old Apr 19, 2006 | 02:43 PM
1975Stingray's Avatar
1975Stingray
Wondering myself! We'll see after my final distrubor upgrades!
Old Apr 19, 2006 | 05:47 PM
big_G's Avatar
big_G
Thanks Lars....I think I'll order the correct app. carb., as this one (off a 350) is the smaller version..., I assume big-blocks got the larger version?
Old Apr 19, 2006 | 07:06 PM
Kalway's Avatar
Kalway
Nope. q-jets only came in one size, essentially. 750cfm for 1975 and older and 795cfm for 1976+
You probably need to put bigger jets in.
Old Apr 20, 2006 | 10:35 AM
lars's Avatar
lars
No, the BB carb is the same size. The SB carb will run just fine if correctly set up - you may need to richen it just slightly for the BB application. The only Q-Jets that were bigger than 750 cfm were the 455 SD Pontiacs and the 455 Stage I Buicks, and they were 800.
To Attn. Lars
