Where does heater core leak from?
Old Apr 25, 2006 | 12:24 PM
desi's Avatar
desi
Default Where does heater core leak from?
I thought once the heater core went, it would leak inside the vehicle near the passenger feet. I can see mine leaking under the hood, on the fire wall. Is this defective core or just the putty that holds the cover? I have the motor apart right now, so this might be the best time to fix this.
Old Apr 25, 2006 | 12:28 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Most of the time they leak from where the inlet / outlet tubes mate to the core itself. from here it can drip and go whever the fuild will travel
Old Apr 25, 2006 | 01:13 PM
Paul L's Avatar
Paul L
The coolant can find its way just about anywhere but normally the sealant on the blower fan housing prevents a firewall exit and keeps it moving toward the inside of the car.
Old Apr 25, 2006 | 02:21 PM
Edzred72's Avatar
Edzred72
I have been EXTREMELY lucky, in that both of the cores that went bad for me ('77 & '72 A/C cars) leaked primarily to the outside.
Fluid will find it's way where ever the path of least resistance exists....
Eddie
Old Apr 25, 2006 | 10:16 PM
desi's Avatar
desi
I took the core out tonight. Not a hard job but time consuming. The manual said to take the dash and radio out. I just had to wiggle the core out.
Here's what I found inside
WTF is that? Is that a nest of some sort? There were bird seeds in there
Also, what sealer am I supposed to use? Is "GOOP" the right one? or just black silicone is good enough?
Old Apr 25, 2006 | 10:48 PM
Z-man's Avatar
Z-man
Looks like you had mice!!
Silicone is good, probably better than the goop you mentioned...
Old Apr 25, 2006 | 10:57 PM
pauvil's Avatar
pauvil
Get a cat!!!
Old Apr 25, 2006 | 11:04 PM
myoriginal77's Avatar
myoriginal77
Good thing you caught it now, would have been a PITA later. Place some traps in your garage or they will be back.
Old Apr 26, 2006 | 07:54 AM
desi's Avatar
desi
How do they get in there though? The unit is completely sealed, isn't it? Unless I have one living inside the Vette...
Shouldn't there be mice droppings there too?
Old Apr 26, 2006 | 11:05 AM
gonzo14's Avatar
gonzo14
Mice can find their way into almost anything, I MEAN ANYTHING!! REALLY. The best weapon of choice is the "boxed" Decon (the little green pellets that are in a box shaped like a slice of cheese). This works fabulous, although their is a chance the dead mouse might be found in your blower again (takes a little while for decon to kill that pesky rodent). Mouse traps in your case would work better initially (USE VERY SHARP CHEDDAR CHEESE), then go to the boxed decon for future protection. I have two cats and they work wonders if you can keep them outside like I can (live on 3 acres). Cats are better than any trap as long as they are OUTDOOR cats only. Indoor ones are TOOO domesticated and lazy. Good luck!!
Gonzo (the mouse hunter)
Old Apr 26, 2006 | 12:01 PM
Edzred72's Avatar
Edzred72
Yeah...the same stuff I found in mine. It's the firewall insulation combined with whatever else those critters dragged in there for their nest.
Eddie
Old Apr 26, 2006 | 12:13 PM
Paul L's Avatar
Paul L
Yes, that's part of the interior firewall blanket. Those little critters were pretty industrious!
Old Apr 26, 2006 | 02:51 PM
Stewart's74's Avatar
Stewart's74
Amir, I used 3M window weld to bond the heater box back to the firewall. I heard of people using Butyl tape but I think the under hood temps and heat from the heater core wouldnt be good for it.
Old Apr 26, 2006 | 09:01 PM
desi's Avatar
desi
I could not locate the 3M stuff, but did come across black RTV (rated for 450 deg). That should be good, no?
To Where does heater core leak from?
