Trans & Diff Coolers
Old Apr 28, 2006 | 08:36 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default Trans & Diff Coolers
What type of setups are you guys running? Got pics?
Old Apr 28, 2006 | 09:08 AM
mrvette's Avatar
mrvette
In the past I have used rather LARGE consensing coils from room a/c units, mounted in front of radiator, large enough to not need any radiator tank circuit.....
can't buy anything that size off the shelf.....
just make sure it's a 3/8 line in and out...
GENE
Old Apr 28, 2006 | 09:12 AM
Van Steel's Avatar
Van Steel
It will be going in a race car that no longer has the battery or storage box. I was thinking along the lines of a 1350 pinion yoke with a pulley connected to it. I have not actually seen the yoke in person to make any measurements. I was kind of wondering if anyone has ever gone that route as well. Here's a pic
Old Apr 28, 2006 | 04:06 PM
Van Steel's Avatar
Van Steel
ttt. somebody has to have something out there. TT any suggestions??
Old Apr 28, 2006 | 05:30 PM
redvetracr's Avatar
redvetracr
VS, The stock car guys use a two stage dry sump pump that mounts to the front bearing carrier of a 9" ford diff and a yoke with a pully as you describe, you might look at an electric bilge pump as sold by Tilton.
...redvetracr
Old Apr 28, 2006 | 05:40 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I run an allison dump truck tranny cooler. I can get pics if you want.
To Trans & Diff Coolers
