72 Shifter Question...
Old Apr 29, 2006 | 01:09 PM
Dave C's Avatar
Dave C
Default 72 Shifter Question...
Very clunky - rebuild or replace??
Who rebuilds them - DIY Kits available???
Replacements - Hurst?
Dave
72 Ontario Coupe 350/4spd/AC
Old Apr 29, 2006 | 09:40 PM
glen242's Avatar
glen242
I have a Hurst Comp/Plus on my '76. Absolutely no comparison to the stock shifter. I LOVE it.
Old Apr 29, 2006 | 10:26 PM
MWieczorek's Avatar
MWieczorek
I had the same problem with my '72... The stock shifter was all slop. It was really hard to find the gears. So, I replaced it with a Hurst Competition Plus unit. It was a royal pain in the rear, and took about 12 hours to get it right. Now that its in, it is SWEET. Short throws and a very positive feel. I like it. If you go this route, make sure you buy the installation kit, the mounting plate is in there, and you have to use the included linkages and transmission levers. Oh, and do yourself a favor and remove the rear transmission mount plate from the get go, it makes getting to those adjustable linkages possible.
Just my experience...
Mwieczorek
Old Apr 29, 2006 | 11:20 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
The stock shifters are good for LINKAGE LOCK!
I put Hurst Competition Plus in my 76 and what a HUGE difference. I just installed one in my 78 & I just got one for my 69. I tried "rebuilding mine with little difference.
GET A HURST
Old Apr 29, 2006 | 11:28 PM
Cory1970's Avatar
Cory1970
I have had Hurst shifters and stock Muncie shifters in different cars. The Hurst feels better, but a well set up stock shifter can still feel great. The key to the stock shifter is setting it up in the short throw position and correctly adjusting the linkage to prevent lock up.
Old Apr 30, 2006 | 07:21 AM
Dave C's Avatar
Dave C
Thanks SO much for the great feed-back - I've always like the Hurst Shifters in my other cars (not Vettes) - it only seems natural that it would be a nice add to the 72 - is the throw shorter?
DC
Old Apr 30, 2006 | 07:41 AM
theandies's Avatar
theandies
Although I don't have the Hurst shifter I have driven cars that have one and they are sweet. Having said that, I agree that a well setup stock shifter performs good. I rebuilt mine a few years ago and that made a great difference and I just recently set it up for short throw and now it is really fun to drive. It depends on your budget. Less than $100 for a rebuild (I think it's even cheaper than that, get the deluxe rebuild kit) or $200 to $400 for a Hurst (depending where you buy it unless you go used). Also keep in mind if you want the stock look then you are going to have to buy a stock looking shift lever for the Hurst and the vendors are very proud of those which will cost you close to $100.
To 72 Shifter Question...
