Advice needed
Old Apr 29, 2006 | 01:58 PM
stingraynick75's Avatar
stingraynick75
Default Advice needed
I have an opportunity to buy either an alum. vortec head set w/ valve covers, performer intake,carter 650 cfm carb. roller rockers and a cam for $900. But the heads are 58cc and I have 9-1 flat top pistons which will make my compression ratio ?? or a brand new set of Trick Flow twisted wedge heads for $850.
Any advice would be appreciated
Thanks Nick
Old Apr 29, 2006 | 04:12 PM
rcread's Avatar
rcread
Are they truly flat top pistons or do they have valve reliefs? If they are flat tops, a 58cc head and compressed gasket thickness of .051 will give you just under 11:1 compression, which may or may not be too high depending on the specifications of your cam. With that high of a compression ratio, you will want to keep the intake valve open a little longer to reduce the pressure a bit.
Old Apr 29, 2006 | 09:25 PM
glen242's Avatar
glen242
Thanks Nick
Didn't know TF was making twisted wedge heads for the SBC again. Does their new catalog show them?
When I bought my TF heads, all they offered was the 23*.
To Advice needed
