NPT sizes
Old Apr 30, 2006 | 04:38 PM
Indynut's Avatar
Indynut
Default NPT sizes
OK, does anyone know how I can tell the difference between some of the NPT measurements i require. I have to block some points on my intake and then there is my fuel pump fittings. I know some mechanical pumps are 3/8 NPT and others are 1/2 NPT. Is there a chart anywhere that I can compare with my vernier measurements and then I'd get my Jegs order going tonight.
Thanks as always!
Indy
Old Apr 30, 2006 | 04:41 PM
GTR1999's Avatar
GTR1999
check with www.mcmaster.com they might have some online help.
Old Apr 30, 2006 | 05:13 PM
StickShiftCorvette's Avatar
StickShiftCorvette
The TAP DRILL for 1/2-14 NPT is .703" (over 5/8"!). Pipe is sized on nominal inside diameter so the drills are large relative to the nominal size (pipe has relatively thick walls). The chart below should allow you to figure out what you have and or need:
NPT Size-Pitch Tap Drill Decimal Inch
1/16-27 .242
1/8-27 .332
1/4-18 .438
3/8-18 .562
1/2-14 .703
To NPT sizes
