Brake Caliper Pistons
Old May 1, 2006 | 01:56 PM
ajkogut's Avatar
ajkogut
Default Brake Caliper Pistons
Do these ever need replacing or are they generally reusable when rebuilding calipers? Obviously, if anything is seen in a visual inspection, I will replace but otherwise, is it necessary?
Old May 1, 2006 | 02:07 PM
Garys 68's Avatar
Garys 68
Not unless there's a problem. They are not even included in the standard rebuild kits.
If you go with O rings (my choice) then you need new pistons.
