3 inch exhaust
Since I have to run a Cat. I am taking this kit, and using two Flowmaster Y connectors ($40 each :eek: :eek: ) The Flowmaster Y is two parallel 2 1/2 pipes smoothly blending into 1 3" pipe. Right before the Cat, both pipes will go into the connector, then into a 3" cat, then through another Flowmaster connector, which will then split the 3" exit of the cat. into two 2 1/2" pipes again.
It is a little bit of custom work but it should be awsome. At the end, I am going to try running no mufflers and use some of the Targa tips I am getting from another CForum member.
Send me an e-mail if you have any questions. I can then get part numbers and maybe draw up a picture.
Yes, in California, don't confuse the legislature with facts, they Knows what they Knows!
Everytime I read a post like sd pacecar's, I am so thankful my '69 is exempt from cats, egr, closed air cleaner elements, and other mandates.
Chuck
P.S. I actually overheard two guys talking here in Florida a couple of days ago about how a local Midas muffler shop wouldn't install a dual exhaust system on their car because it was against the law (The car did not come with duals originally). It's against the law, but it's just whether your state will let you get away with it. Even though Florida will let you get away with it, some muffler shops won't do it because they are technically breaking federal law.
[Modified by 79MakoL82, 1:20 PM 8/23/2001]
).Anyway, for what it's worth, I finally went with a 2-1-2 system. I have the stock manifolds (2"). Off each of those there is a short (maybe 4") pipe that expands out to 2-1/2". The two 2-1/2" pipes join at a 3" collecter in front of the CC. It's a hi-flow CC with a 3" inlet and two 2-1/2" outlets. Then it's 2-1/2" for each pipe all the way back to my MagnaFlow mufflers. So, I guess the CC and the muffler pipes technically make up the rear Y. The muffler shop said that they wouldn't pass true duals with dual CCs, but they were fine with this configuration.
I'm sure that I could have found a place to pass true duals, but I just didn't want to take the risk. I've asked about this setup and several sources (including Corvette Fever) have said that it should be good for up to 400HP. Probably something that I'll never exceed, but it still just doesn't FEEL right, not having true dual exhaust on a Corvette.
It sounds good. I think I should have picked Flowmasters because I like LOUD and the MagnaFlows are quite a bit quieter. I have no first hand experience with Raven, but I heard people on this forum speak well of them; maybe some will chime in.
I have some pics posted if you're interested.
http://users.erols.com/jerryp58/corvette/exhaust1.jpg
http://users.erols.com/jerryp58/corvette/exhaust2.jpg
http://users.erols.com/jerryp58/corvette/exhaust3.jpg
http://users.erols.com/jerryp58/corvette/exhaust4.jpg
Good Luck & let us know what you decide.
[Modified by jerryp58, 2:05 PM 8/23/2001]
I would tend to think any improvement over the factory set-up would be worth the money and effort, especially concerning the exhaust system. IMHO
love to drive- Are you saying the Ravins are louder than the Flowmasters or do they have a better/different sound?
