Wire Looms?
Old May 8, 2006 | 01:34 PM
doug.storch's Avatar
doug.storch
Default Wire Looms?
Lucky for me I dont post pics yet because if you saw my plugs and wires that I took off this weekend the Vette police would take me away!
Found three loose plugs, two burned wires, and a plug boot missing a connector. She was running pretty good for a 3.5 cylinder!! (maybe it was 2?)
This brings me to my question: Anyone have any recommendations for wire loom kits they have used? I plan to go next to or over the rocker covers as the underneath just did not work out.
Old May 8, 2006 | 02:06 PM
Roadster71's Avatar
Roadster71
I have the same question, only for center bolt valve covers.
Old May 8, 2006 | 03:06 PM
audiec's Avatar
audiec
Here are some links to some nice looms, I have seen some that hug the side of the valve cover, but only on Big Blocks. The last link is for fibergalss wire boots, good wires are to much to burn up on headers...
http://www.jegs.com/webapp/wcs/store...tegoryId=28653
http://www.jegs.com/webapp/wcs/store...tegoryId=13211
http://www.jegs.com/webapp/wcs/store...tegoryId=15643
http://www.jegs.com/webapp/wcs/store...hItemId=254523
http://cableorganizer.com/insultherm-spark/
Audie
Old May 8, 2006 | 03:19 PM
Hvymtlc5's Avatar
Hvymtlc5
I use these and really like them for keeping the wires organized. Will bolt to you valve cover.
http://store.summitracing.com/partde...5&autoview=sku
doug.storch
Thanks Audie
I looked at Summit but not Jegs. :o
I like the "blue" Proform ones best!
Anyone have pics of some in the car?
Old May 8, 2006 | 03:47 PM
audiec's Avatar
audiec
This is the type I wanted and seen on Big Blocks. The BBs have 3 bolt holes, won't work as well on small blocks and not at all with center bolt type. I went with the side mount type, theywork really well and don't look bad.
Audie
Old May 8, 2006 | 04:11 PM
Kid Vette's Avatar
Kid Vette
I like these from Moroso.
Old May 23, 2006 | 05:25 PM
68 NJConv 454's Avatar
68 NJConv 454
Roadster 71...check out this link below...look for ahoovers pic, they are really nice if you have the center bolt covers. 5th post down 1st pg.
http://forums.corvetteforum.com/show...ght=wire+looms
Anyone know the benefits of running your wires underneath the headers rather than over top along side the heads?
Old May 23, 2006 | 07:03 PM
TopGunn's Avatar
TopGunn
I used these with the aluminum brackets. They run along the edge rather than in the center of the cover.
http://www.made4uproducts.com/centerbolt_kits.htm
Old May 23, 2006 | 10:25 PM
VETTEVIC's Avatar
VETTEVIC
Heres mine
Old May 23, 2006 | 10:38 PM
Jclgodale3's Avatar
Jclgodale3
Originally Posted by VETTEVIC
Heres mine
Same here. Here's mine
Old May 23, 2006 | 11:13 PM
Al77Vette's Avatar
Al77Vette
I used these.
Old May 24, 2006 | 01:21 PM
doug.storch
I went with this set as well. It really made a difference in the look of my engine compartment.
Heres the installed product:
To Wire Looms?
