Feul Pump
Old May 8, 2006 | 06:27 PM
Oldguard 7's Avatar
Oldguard 7
Default Feul Pump
I read the installation instructions for the installation of my new feul pump. It mentions to lubricate the pump lever where the push rod makes contact and the area where the cavity where the lever sticks out? What is the best type of grease to use? Does one need to lubricate the push rod before placing the rod inside the block?
Old May 8, 2006 | 06:40 PM
Strats-N-Vettes's Avatar
Strats-N-Vettes
Friend Request Magnet
Originally Posted by Oldguard 7
I read the installation instructions for the installation of my new feul pump. It mentions to lubricate the pump lever where the push rod makes contact and the area where the cavity where the lever sticks out? What is the best type of grease to use? Does one need to lubricate the push rod before placing the rod inside the bloxk?
Assembly lube if you have it...that would be the best.
Vasoline.
Any light graphite grease (ummm...dont get it on anything white).
Even a light coating of axle grease is OK.
If you do lube the rod very well, it will help hold the rod in place upon installation of the fuel pump.
Its actually not anything as drastic as it may seem...been done many years, many times without lube at all...its just added insurance per se'.
GL
Jim
Old May 8, 2006 | 06:58 PM
mensch53's Avatar
mensch53
i used general axle grease
Old May 8, 2006 | 07:24 PM
C3 Stroker's Avatar
C3 Stroker
I used a dab of grease (lube) from my grease gun.....it also helped hold the rod up in place when I installed the pump.
To Feul Pump
