brake issue
Old May 9, 2006 | 07:32 PM
61loub's Avatar
61loub
7th Gear
Default brake issue
Saturday, I replaced front calipers and pads on my 82. Car brakes fine but right front makes grinding noice and appears to be digging in to the rotor. Haven't pulled wheels yet but am lost. Simple, fixed, dual piston caliper about as easy as it gets. The caliper was leaking on this side and did not appear to be working at all. You could see the leaking calliper and the car pulled badly. Any suggestions, what am I missing????
Old May 9, 2006 | 11:25 PM
SIXFOOTER's Avatar
SIXFOOTER
you got something put together wrong, antirattle clip between pad and rotor maybe? Pad Failure? pull it off and see WTF?
Old May 9, 2006 | 11:34 PM
wombvette's Avatar
wombvette
ER ugh, you didnt put the pads on backwards did ya?
Old May 10, 2006 | 04:15 AM
kb2fzq's Avatar
kb2fzq
Sounds like a caliper piston hanging out....possible...jack up that wheel, apply brakes, then see if you can spin that wheel...if it's tight or won't turn, a piston is out...
Old May 10, 2006 | 04:21 PM
61loub's Avatar
61loub
7th Gear
Thanks for the input. I am going to pull it apart tonight and see what gives. I'll let you know. Thanks again.
Old May 12, 2006 | 01:25 PM
61loub's Avatar
61loub
7th Gear
Duh.... Feel stupid, pad on backwards was the answer.
Old May 12, 2006 | 07:35 PM
wombvette's Avatar
wombvette
At least you came back and admitted it. Stuff happens.
Old May 12, 2006 | 08:50 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
at least you didn't back the car out of the garage with the hood up.....that happened to a guy right after a paint job...he was paying too much attention to make sure he didn't hit the side of the garage....
Old May 12, 2006 | 09:15 PM
CF6873's Avatar
CF6873
Many years ago when I worked in a body shop, we had just finished painting a 69 Chevelle and when my boss backed the car out of the shop he had the drivers door open just enough to hit the garage door opening and bent the door in half. I couldn't laugh in front of him but I was laughing on the inside because this guy thought he could do no wrong.
Old May 12, 2006 | 09:22 PM
kdf1986's Avatar
kdf1986
And we have a winner!!!!!
Sometimes it is the most basic things that we need to check first.
61loub, thanks for posting back what the solution to the problem was. Too many times we ask for help, or requests, and then never post what the solution was.
kdf
To brake issue
