Battery Dead? again...
Old May 13, 2006 | 06:08 PM
dyanisis2's Avatar
dyanisis2
so how would i test the antitheft relay to see if it is bad or not? I dont know of the short is there or somewhere else in the system.
Old May 14, 2006 | 02:23 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Replace it with a known good unit and see if the problem corrects itself?
Old May 14, 2006 | 08:49 AM
kb2fzq's Avatar
kb2fzq
so i did the meter test as described in this thread. It initially was reading 275 ma- which i guess is why the car is dead if i don't run it for a week. I found the antitheft fuse was what was causing the problem- when i disconnect the antitheft relay it drops down to 70 ma. So how do i test the relay to see if the relay itself is shorting out or if it is somewhere in the system- not necessarily the relay?
Pull that fuse for a week and make sure that is the problem....you might have numerous culprits...if the battery stays up enuf to start the car after a couple of days you're good...ummmmm....do you have a lot of corvette thieves in Utah?
Old May 14, 2006 | 03:48 PM
dyanisis2's Avatar
dyanisis2
lol- definately not many corvette thieves in utah. Especially my worn out vette- its not restored yet.
Old May 15, 2006 | 08:19 PM
keverson's Avatar
keverson
My battery drain was caused by the horn button. The horn was unplugged when I bought the car. When I plugged it in, the horn stayed on. The button was always making contact, draining the battery.
Old May 16, 2006 | 02:54 AM
VetteLS6's Avatar
VetteLS6
LMAO
I hope it wasnt hard to figure that source of battery drain
