Corvette Engine Rebuild Question
Old May 11, 2006 | 12:27 PM
RDOldcars's Avatar
RDOldcars
Default Corvette Engine Rebuild Question
I need some insite on rods for a 1970 454-390 HP Vette, (TH400). In the 70 Vette did it come with a pressed in wrist pin or a floating pin on the pistons? I am buying a block without rods, I plan tp pick up some rods but I am not sure about pressed or floating pins. The engine will be stock(mostly) so I don't need any super duper rods, whatever was stock from GM should do. What were stock rods for this motor?, dimpled rods? This will be a 2 year project so I am in no big hurry. Any info would be greatly appreciated, any suggestions on the rebuild would also be helpful. I guess I would like to bump up the HP to a max of 450, will stock rods handle this? Any suggestions to get it to 450? I have a set of closed chamber heads(3964290) that have recently been redone, new valves, springs, retainers,hardened seats, etc,etc, I bought them that way so they are ready to go, oiled and put in plastic bags for future use.Any cam suggestions,pistons (cast or forged), whatever you can think of.
Best Regards
Bob in Boca
