can't start
Old May 19, 2006 | 08:09 PM
curtisl0we's Avatar
curtisl0we
Navigator
Default can't start
if i have no power to my ignition wire would it be safe to say the likely culprit is the ignition switch.exuse my ignorance.
Old May 19, 2006 | 09:09 PM
wnjlt1's Avatar
wnjlt1
what year vette? do you have no power to the ignition switch (interior ignition key assembly) or no power to the distributer module or do you have no spark @ the ignition coil or spark plug wires?
Old May 19, 2006 | 09:14 PM
luerja's Avatar
luerja
take a jumper wire from the positive side of the alternator to your distributors positive side and turn the key and see if you get juice to the plugs..... if not then the issue is before the ignition.
or put a voltage meter on the positive wire while the key is on to see if your even getting power?
Jim
Old May 19, 2006 | 10:13 PM
curtisl0we's Avatar
curtisl0we
Navigator
1978 & no power to wire with volt meter
Old May 19, 2006 | 11:20 PM
SIXFOOTER's Avatar
SIXFOOTER
check the fuse, check the switch, check firewall connectors
To can't start
