body mounts rusted out
Old May 22, 2006 | 08:32 PM
rkrattli's Avatar
rkrattli
Default body mounts rusted out
Serious problems today.. doing a lot of body work on my 75 stingray, and it turns out that the front body mounts (behind the fenders and the door) and the mounts in the rear wheel wells are real rusted out. I dont have any pics, but I gotta say that it looks pretty bad. It's not the brackets, its the upper part that's molded into the fiberglass. Is this repairable? Do I need to do a body-off restoration?
Old May 22, 2006 | 08:54 PM
Glassbowtie77's Avatar
Glassbowtie77
Hard to say without pics.
Old May 22, 2006 | 08:57 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Birdcage repairs...fun. Start searching the archives.
Old May 22, 2006 | 09:54 PM
LYLE's Avatar
LYLE
I think what you are saying is the #3 body mount is pushed thru the bird cage. I live in salt country and lots of sharks I look at have this problem. The rubber cushion was only about 1/4" larger than the hole in the bird cage. With the body off and if this is the only area that is rusted out it is a pretty easy fix with the right tools. You may find many more problems once the body is off. You may just open a keg of worms and that is the way many vettes are sold. The owner has no time for a lot of work no tools for the job amd loses intrest fast.
Lyle
Old May 22, 2006 | 10:02 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
If I understand your question, many Corvette Parts vendors carry botht the front #1 and rear #4 brackets.
Here is the #4 bracket from Paragon:
http://www.corvette-paragon.com/cata...7-8CDCEE93CA5D
Here is the #1 Bracket
http://www.corvette-paragon.com/cata...8-D522308D21AD
Old May 22, 2006 | 10:16 PM
chris73cpe's Avatar
chris73cpe
If you are talking about the #3 mount, it probably will be a body-off fix because you're rocker channels are toast, but the #4 isn't that bad to do with the body on. here's what mine looked like a few months ago and what it looks like now.
before:
after:
You will have to lift the rear of the body off the frame a few inches, but iit's way less work than pulling the whole thing. I got my replacement reinforcements from zip and they still needed a little fitting to get right. Mine #1's were ok, but they look pretty easy to get to as well. Be careful though, once you start pulling things off the frame, you might get tempted to keep going and spend way more time/money than you intended.
Old May 22, 2006 | 11:13 PM
Edzred72's Avatar
Edzred72
Originally Posted by chris73cpe
after:
I remember when you started this repair...Very nice work Chris Stainless screws is the way to go!!! Take a Bow and a beer.
Eddie
Old May 22, 2006 | 11:18 PM
chris73cpe's Avatar
chris73cpe
Eddie
believe me, I've already had more than a few beers because of this project... I was kinda lucky that I was tearing out everything on the rear end so there wasn't that much more to do to get the mounts off. I owe a lot of people on this forum some thanks for their help and advice.
Old May 24, 2006 | 02:47 PM
tomzss's Avatar
tomzss
Nice work Chris.
Since the original brackets are riveted on what did you screw into? The fiberglass or is there some sort of backer plate.
Also, what did you use on your frame? It looks great.
Tom
Old May 24, 2006 | 03:41 PM
iree75's Avatar
iree75
Had to do the same thing on my 75. The rivets just hold the #4 mounts in place. I used pop rivets with backing plates. Remember to use fiberglass filler when setting the #4s as well. Check out my vette photos next to my avatar.
Old May 24, 2006 | 04:43 PM
joews's Avatar
joews
My # 4 mount is rotted out on my 76 and I need to replace also. What if any problem would I have if I drive this summer and do the job next winter.
Old May 24, 2006 | 08:43 PM
Edzred72's Avatar
Edzred72
Originally Posted by tomzss
Nice work Chris.
Tom
Probably stainless machine screws, nuts, washers. That's what I did.
Eddie
Old May 24, 2006 | 08:46 PM
Edzred72's Avatar
Edzred72
If the #4 mount metal reinforcment is rusted to shreds...you run the risk of damaging/crushing the fiberglass under it by driving. Ask me how I know....
Eddie
Old May 24, 2006 | 08:47 PM
chris73cpe's Avatar
chris73cpe
ss machine screws with a washer and nylock nut on the inside, 3/4" works for most, but some needed 1" to get started. I just used polyurathane construction adhesive for a filler, fiberglass filler should work too but you won't get as much time to mess with it. I did have to do some minor fiberglass repair on one side from the reinfrocement being so far gone, something to keep in mind if you're thinking about driving on a bad mount. The thing that really scared me when I pulled the old mounts off was the condition of the frame side mount, it was just about rusted away to nothing, and the rest of my frame is actually in pretty good shape.
frame is just painted with semi-gloss rustoleum, came out really nice but now I have to tear the front apart to finish painting it... next year
Old May 24, 2006 | 08:56 PM
redwingvette's Avatar
redwingvette
I had to fix them all. Body-off project
Check the frame as well. Most of the time the brackets are rusted out too.
To body mounts rusted out
