Test dash gauges?
Old May 28, 2006 | 08:22 AM
1996Z15's Avatar
1996Z15
Default Test dash gauges?
Is there anyway to test the gauges in the center dash? The fuel gauge and oil pressure gauge on the car I recently bought aren't registering. The fuel gauge is just off, it would seem, and the oil pressure doesn't seem to be working. Before I get the car registered and start to drive it can I test these gauges? Should I just buy replacements or could it be something that's easily fixed?
Keep in mind the car was rarely driven before I purchased it a few weeks ago.
Old May 28, 2006 | 09:47 PM
1996Z15's Avatar
1996Z15
Ttt
Old May 28, 2006 | 10:09 PM
rexx78's Avatar
rexx78
In my 78, the oil pressure gauge is electric, maybe the wire to the pressure sensor is off or broken. On my 78, it was on the side of the engine by the filter, sometimes it is on top of the engine at the back beside the distributor.
Maybe the fuel gauge linkage in the tank is gummed up?
Old May 28, 2006 | 10:24 PM
fast idle's Avatar
fast idle
turn the ignition on and get a test light.ground out the clip on the light and touch the wire in question to the tip.if it doesn't light up the test light,it isn't the gauges.follow the wire back until you find wherever the break is.if the light works but the unit doesn't,check for ground.hook the clip of the light onto power and test the light on the ground wires.if it doesn't light, it's the ground.
ps....check the ground first.mike
To Test dash gauges?
By Michael S. Palmer | 2026-06-03 11:00:24
