A/C conversion
Old Jun 2, 2006 | 07:53 PM
jlelec's Avatar
jlelec
Default A/C conversion
Can anyone tell me the proper way to convert my 81 to R-134. Have heard all types of methods and tales. It currently has R-134, but I think the previous owner must have missed something. It cools but not good. Help!
Old Jun 2, 2006 | 08:54 PM
zwede's Avatar
zwede
If you don't have an adjustable cycling switch you need to get one. You need to cycle at a lower pressure w/ R134a.
Also replace the stock orifice tube with a "smart VOV" (google for it). With those two changes, and if the rest is in good stock consition, your vent temps should be in the lower 40's even on a hot day. You can get an AC thermometer at any parts store for $5 or so to verify.
Old Jun 2, 2006 | 09:43 PM
Adam Wartell's Avatar
Adam Wartell
Could you expand on the "adjustable cylcing switch" part?
I bought a kit a few years ago that basically just had some adapters for the hose fittings and a can of R134. Was that not enough?
Thanks!
Old Jun 2, 2006 | 09:52 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
I hope you didn't just bleed off the R-12 & juice the system with R-134. The compressor oils are not compatable between R-12 & R-134. There are some oils & refridgerants that go both ways, but you specificly have to replace the original oil.
Old Jun 2, 2006 | 10:22 PM
jeckel's Avatar
jeckel
Check out this tech artical from zip. It might help you retrace the system to see if something is missing.
Zip 134a Conversion Artical
Old Jun 2, 2006 | 11:04 PM
zwede's Avatar
zwede
Your stock system has a cycling switch. When the AC is on the compressor will run for a while and then shut off, then back on etc. The switch will shut the compressor off when the pressure goes below a set value. The optimal pressure for cycling is lower for R134a than R12. Some factory switches are adjustable, some not.
To A/C conversion
