Supercharger question...
Old Jun 3, 2006 | 05:15 PM
Summerfun's Avatar
Summerfun
Default Supercharger question...
The Vortech supercharger has an oil line to it and one from it back to the engine.
I will just connect the return line to the valve cover.
Question is, do I need some kind of restictor in the return line or just let it flow freely back into the valve cover? Won't this drop the oil pressure without a restrictor or does the supercarger bearings act as a restrictor in some way?
Old Jun 3, 2006 | 06:01 PM
Greg's Avatar
Greg
Just another Corvette guy
Unless the feed line and return lines are the size of a radiator hose you shouldn't see any drop in pressure.
Greg
Old Jun 3, 2006 | 06:27 PM
supervette2's Avatar
supervette2
Thats a good question. I would call Vortechs tech line and ask them. But you did tap your line and it will draw up as much as is needed it will be a recirculating deal so im sure it will be alright. I hear you dont want one bent or clogged. Be very nice with them as they could be very detrimental. Im curious to see pics. Im doing a very similair deal with a procharger.
Old Jun 3, 2006 | 06:29 PM
supervette2
what model did you go wtih?
Old Jun 3, 2006 | 07:12 PM
Summerfun's Avatar
Summerfun
Vortech V7Ysi Big block supercharger.
Click the link and scroll down to the pics of my dusty car right now.
http://forums.corvetteforum.com/show....php?t=1398584
I'm just wondering......
.....if there is x-amount psi oil pressure in the engine, this pressure will be at the supercharger as well. I don't know what happens inside the supercharger to lower the pressure through its bearings maybe.
If that x-amount of pressure goes to the return line, I will have to make some type of screw on connection to the valve cover or it will blow right off. No?
I have myself second guessing my own logic.....
Old Jun 3, 2006 | 07:19 PM
comp's Avatar
comp
all i have seen drain into the pan
Old Jun 3, 2006 | 07:28 PM
Summerfun's Avatar
Summerfun
....so it must be a screw in connection as a hose clamp will come off due to the high pressure in the return line?
To Supercharger question...
