So I'm shimming my trailing arms out, when I notice the passenger side T-Arm bushings are pushed out on both sides and are sitting flush against the inside of the frame rails (See pic below)
Any recommendations on a way to re-insert them back into the arm without removing it or damaging the bushings, or am I looking at a T-arm de-install to fix it?
I just replaced my TA's. Shouldn't there be shims there? It shouldn't have anywhere to move if the shims are there. Or, maybe I need glasses!
Yes the shims go in there but I can't because the bushings are pushed out on both sides. They're poly bushings, and was thinking if I could get a fork-like tool that was thin enough to get behind the bushing but strong enough to push it in. Otheerwise the arm has to come out, what a pain (like everything else has been in the home stretch here)
Would this damage the bushings, or are there other concerns as to why they slid out of the arm?
Stump, same thing happened to me when i went to install the long ta bolt which pushed the inner poly bushing center insert out. worked it back in with a slightly angled prybar.
I think I would be a little concerned why they came out. I bought my arms as complete assemblies and the bushings were tight within the arm. They were not poly. If you havent put any other suspension components on maybe you could just pull them back out and have a look. Also for reference, I installed my shims as I removed them. It turned-out to be 1/2" in the insides. The first time on the alignment rack I saw my toe was out. A 1/8" shim movement from one side of the arm to the other changed the measurement about .47 degrees.
Cool, gonna go for it. The suspension is completely installed so I'm dreading taking the arm out...
The inner and outer halves of those bushings have to be staked together. Yours obviously weren't, so you need to remove the T-Arms and properly stake the bushings.
Poly bushings do not have to be staked but I have read a lot of posts that say they are not the best bushing to use in this application. They wear faster than the original rubber ones. You could try prying them back in but if it were mine I would pull the TA and push them back in, install using plenty of grease on the bolt and shim both sides equally until you could have it aligned. Hope you get it going!
Bernie
Yeah right. There is no way that poly is going to wear faster than crappy rubber in any circumstance. You should see the 6-year-old bushings in my 2000 Cherokee.
If it is freshly assembled the TA bolt MIGHT come right out. You could try wedging the bushing over with a small pry bar but when I assembled mine the bolt was well lubed before assembly and slid right in. I put most of the shims back in at that point at the approximate thickness they were on disassembly. Good luck as it is all a PITA!
I don't know if thats true of all bushing kits; however, I know that my poly bushings from VB&P had the inner sleeve staked on one side and they provided a flaring tool to do the otherside after assembling everthing.
The inner sleeve should be flared to keep the bushing assembly in the T.A.
If you're lucky and get the bushings back in the arm then the shims will hold them in place.
You're saying you just rebuilt the rear ? All your bolts should come loose easily...
the poly bushings on this offset trailing arms which i purchased recently through a supporting vender did not have any washers , spacers or inner and outer flange washers @ the ends of the bushings unlike the stock bushings. it had basically (2) poly bushings, one installed from the inside and the other from the outside of the trailing arm. a center sleeve went through them which was snug in the poly bushings and was not staked. there are probably a few different types of bushings, some that need to be staked and others that don't like this example. Stump, if this is what you have...work the sleeve and bushing back into the arm, install the alignment shims and torque down the nut.
I am very interested in this thread - I live in Aussie and have a 79 which steers badly from the rear. I believe my T arm bushings are shot. I am interested in knowing what other members have used (or made up) to flare the bushing inner steel tube ? I know I could buy a special tool but to buy one and get it sent to Aussie would cost about $200. Any help would be appreciated.
BTW: I am one of the lucky ones as my T/A bolts test moved when I undid the nut and hit them with a hammer (must say something for the weather here, it doesn't snow hence no salt on roads- so looks like I won't have to saw through the bolts like some members have had to do.
Come to think of it why didn't GM make the iner tube in two halves with both ends flared - then we'd only have to bolt them together and maybe pull the bushings in at the same time.
Any suggestions on a home-made flaring tool or other ideas would be greatly appreciated.
The flaring tool is included when you buy the poly bushings from VBP.
