Battery Eating Vette
Old Jun 4, 2006 | 04:23 AM
l979 Corvette's Avatar
l979 Corvette
Default Battery Eating Vette
ok something is killing my battery, but I cant figure it out all the wiring to the alternator is good, gound is good, but my "GEN" light keeps coming on and I just got a new battery today (2nd one it's gone through in 6 months) and it died at the end of the day. And it is a brand new Altenator. Any suggestions?
Old Jun 4, 2006 | 06:42 AM
kb2fzq's Avatar
kb2fzq
Start with ohm meter across + battery post and cable and see what amp draw is with doors closed and engine off, key off...then start pulling fuses until the amp draw drops, determine what devices are on that fuse and check each device/fix the device...
Old Jun 4, 2006 | 06:59 AM
...Roger...'s Avatar
...Roger...
Sounds like your battery isnt getting input from your alt.When the engine is running whats your voltmeter saying?Will the engine stay running if you remove your neg. cable?
Old Jun 4, 2006 | 07:57 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
I would take the altenator off and have it tested It is possible that you got a bum alt
Old Jun 4, 2006 | 08:08 AM
fl_rider's Avatar
fl_rider
Default Things to check...
New cables or old??
Check for corrosion inside the terminal ends,
Ground cable from starter to frame installed??
Check condition of this cable as well.
Old Jun 4, 2006 | 12:59 PM
SIXFOOTER's Avatar
SIXFOOTER
the GEN light is the indicator that is there to tell you the voltage regulator is failing. When the reg dies it provides a partial to complete ground for the light, the other side of the light is switched 12v that is the voltage sensing circuit for the regulator to tell the alternator how much voltage to put out. Replace th regulator and/alternator and problem solved
Old Jun 4, 2006 | 03:04 PM
l979 Corvette
Thanks guys and all the bat cables are new fl rider that was one of the first things I checked was the connection. Hope I get this fixed today I don't like having my Vette down in the summer.
Old Jun 4, 2006 | 04:39 PM
l979 Corvette
I just started the Vette no prob. no GEN light came on, I thought I was set when my altenator started to smoke and whine......I think I may have found the problem.
To Battery Eating Vette
