radiator replacement?'s
Okay guys I removed the radiator and the attached trans cooler from the vette today... I had a small leak under higher rpms, nothing really while putting around town. So like most C3 owners I enjoy working on my car, even though radiator repair/removal is less than fun on the C3's.
My first question is when reinstalling the trans cooler there will be air in the lines. Is there any special process I will need to do to fix this or do I just top off the Tranny and call her good?
Also, is there a better way to mount the trans cooler? It was mounted to the radiator with these black "hayden" connecting tabs.... they were ran through the fins on the trans cooler and radiator with rubber pads in between the two.
Second, I have slowly begun rremoving the air conditioning... (It finally developed a substantial leak) I really don't care for the clutter under the hood associated with A/C and it's a vette... take out the t-tops, roll down the windows and drive it like you stole it. anyway, I removed the A/C condenser... The only adverse reaction to this would be more air flow for the radiator/trans cooler right?
Third, I haven't taken the rad. to the rad shop yet so I don't have a price for repairs but after removing the radiator and deciding I really don't want to do it again. I am contemplating installig a aluminum replacement... I looked at Summitt, all they had for direct/custom fit radiators were Be Cool at around $300-500. I have seen on this forum that Dewitts come highly recommended. After close inspection at there website it seems they are TRULEY "direct fit" replacement radiators. at around $500. Do forum members get any kind of discount for Dewitts orders?
( I hate to sound cheap but, a penny saved is a penny earned )
Any and all help will be greatly appreciated..
"save the wave"
Search for "Best Aftermarket Aluminum Radiator??" and it should come up.
Wish I would have done that in the first place!
AC on. Replaced stock radiator with Dewitts direct fit and stock water
pump with Edelbrock alum. high flow, haven't seen the temp. over 180
since the change and this was with outside temps of high 90s. So
far I think buying the Dewitts rad. was some of the best money I have
spent on car.
I hope gettting it in is easier than taking the C&B one out.
the radiator is the same as the dewitts unit - all aluminum, 2 1" rows, all brazed, no epoxy. More work, not factory appearance, but half the price. I think it was worth it.
I have the same rad, using a universal ribbed lower hose with elec fans and no shroud, rarely turn on the fans
BTW I am running almost all dist water and Water Wetter, very little anti-freeze in the summer.
