71 Frame Question
Old Jun 7, 2006 | 01:55 PM
JoeGermann's Avatar
JoeGermann
Cruising
Default 71 Frame Question
I am in the midst of a body off on a 71 4-spd small block roadster and the frame is junk. The rest of the car is real good and was a one-owner that was very well cared for.
What year frames can I use without modification?
Thanks,
Joe Germann
Old Jun 7, 2006 | 02:12 PM
stingrai's Avatar
stingrai
1969 - 1973 will have the same style rear cross member for chrome bumpers, 1974 started using impact absorbers, and changed the rear cross member. All Manual trans have a bell crank mount, and a welded in trans crossmember, auto's have a bolt in cross member, and no bell crank mount, this can easily be added.
Also, 1973 started using rubber body mounts, so they have a slightly lowered mount points, but can be used
1968 early frames do not have support gussets on the kickups, so not desireable, but can be used
Old Jun 7, 2006 | 03:05 PM
Bob Onit's Avatar
Bob Onit
Default Corvette Frame Changes 1963 to 1982
Heres a little info that might help you...
Never did a frame replacement so this is the best I can offer
http://www.71corvette.com/frames.html
Old Jun 7, 2006 | 03:13 PM
Ed Blue 03's Avatar
Ed Blue 03
Haven't looked into it, but what about the tube steel frames advertised in Corvette Fever, etc. I think that if I ever did a frame-off that would be the way to go, since it should be modern day/hi performance technology.
Old Jun 7, 2006 | 05:29 PM
JoeGermann's Avatar
JoeGermann
Cruising
Thanks for the help and the great information.
Joe
Old Jun 7, 2006 | 09:27 PM
72LS1Vette's Avatar
72LS1Vette
I came across a frame at Rowley Corvette that is a modern interpretation of the C3 frame. It comes in either plain steel or stainless and they have a version that uses C4 suspension components. The main drawback of course is the price. The plain steel stock suspension frame costs ~$4,000.
RIck B.
Old Jun 9, 2006 | 03:25 AM
Bob Onit's Avatar
Bob Onit
RIck B.
Yeah, and they probably have illegal labor pumping a frame out every 20 minutes.
Keep an eye on the For sale section here and Ebay
To 71 Frame Question
