Engine vacuum fitting
Old Jun 9, 2006 | 10:41 PM
Gary B.'s Avatar
Gary B.
Default Engine vacuum fitting
The engine fitting on my 1979 L48 has a crack in it so I replace it with a new one, now there seems to be some interference between the vacuum line that runs to the transmission and the under side of the air clearner. What my question is did Chevrolet come up with a different (shorter) fitting, or a different style other then the cross type. Or does any one have any pictures of how they set theirs up with the three vaccum hoses, using the stock air clearner. Gary B.
Old Jun 10, 2006 | 10:47 AM
palazzopl's Avatar
palazzopl
I put a single port fitting then used two brass tee's to feed the headlights, transmission and cruise control..works fine
