What gears...
Old Jun 11, 2006 | 11:14 AM
jerrylee's Avatar
jerrylee
Default What gears...
Hey guys right now I have a newley rebuilt 454 with a 700r4 tranny but my gears are only the original 3:08's....I want to change the gears so what is the lowest I can go to and still enjoy the parkway ride........Thanx...
Old Jun 11, 2006 | 11:32 AM
vho69's Avatar
vho69
I have 3.55,s and it turns about 3200 at 70
Old Jun 11, 2006 | 11:46 AM
73 LS-4's Avatar
73 LS-4
With a 700R4 and a 454, you can probably go with 3.73's becouse of the overdrive and still have good gearing for accleration around town. I run 3.55's with my 4spd and anything more then that would greatly reduce my highway useage. I'd say 3.55's if your spending the majority of time on the highway and don't plan on racing much or 3.73's if you tend to do any sort of competition use and still want to be highway friendly.
Pat Kunz
Old Jun 11, 2006 | 05:29 PM
Emeightch's Avatar
Emeightch
I went with a 3:7.
Old Jun 11, 2006 | 05:38 PM
Little Mouse's Avatar
Little Mouse
The 700R4 has a stump pulling first gear and you have a big engine
I would not stray far from the 308s say 355 that big 454 will pull
some overdrive.
Old Jun 11, 2006 | 07:50 PM
MIKER's Avatar
MIKER
The overdrive would easily allow for 4.10:1 ratio for cruising the open highway but as Little Mouse stated, you would likely be more satisfied with something in the 3.08:1 to 3.55:1 with the big block.
Unless you have run out of Corvette related things to spend money on I would stay with the 3.08:1 gears for a while.
Play with some of the online rpm vs. speed gear ratio calculators.
I've always liked the ones at smokemup.com
Old Jun 11, 2006 | 08:14 PM
jerrylee's Avatar
jerrylee
hey mouse what do u mean by a stump pulling 1st gear...and thanx for the input guys..............
Old Jun 11, 2006 | 08:52 PM
Little Mouse
I don't know much about autos but a 3.27 low gear anything is a
stump puller to me I have a 12.76 low gear in my truck and
4.33 rear gears I can recomend if you need some more grunt down low,
you don't mind a top speed of 7 mph in first gear do you.
one of my mack trucks had an 18.1 low gear and a 36.1 reverse
gear. you could put the truck in reverse gear run the truck up to 2300
rpm ( maximum ) open the door look at the ground and you would be barely moving. The mack truck did have five reverse gears to
choose from so you could go faster in reverse then a turtle if you wanted to.
Old Jun 11, 2006 | 09:48 PM
markdtn's Avatar
markdtn
I have TPI and a 700R4 and 3.7 gears out back. To me it is way too much gear. First gear is useless. I have 3.36s and will put them in, maybe this winter. It does depend on what you want the car to do. If you just want to cruise, then 3.08 or 3.36. If you want performance, then 3.7 or 4.1.
To What gears...
