Header questions
Old Jun 13, 2006 | 05:33 PM
Berserker78's Avatar
Berserker78
Default Header questions
I am looking at putting in a set of headers, but have a question on them.
My biggest reason for putting them on is the fact that my heavy duty idler arm is only about 1/16" from the exhaust pipe on that side and I wouls rather put on headers than go back to the normal idler arm.
My obvious second reason is wanting the look/performance of headers.
It looks like there are two types that people are selling for them:
MAD Type:
Other:
The first is the standard headman type, the second is just some generic style. I lean toward the second both because I prefer equal length headers and because it moves everything further toward the firewall. I have underfloor insulation, so I am not worried about the heat, but are there space or any other kind of issues that I should be aware of?
Anyone have any good pics of thier header install? Does most everyone have problems with the spark plug wires?
Old Jun 13, 2006 | 06:17 PM
guppie's Avatar
guppie
St. Jude Donor '08
I had to go to Accel shorty spark plugs because the headers were too close to the plug wires. I have the Patriot headers from Corvette Central
Old Jun 13, 2006 | 07:05 PM
Berserker78
I could definately see that being a problem with the hedman type as well. What kind of difference did you get putting those headers on? What is the rest of your exhaust system?
I have the true duals with some lame cheapo mufflers, they will be the next to go.
Old Jun 13, 2006 | 08:53 PM
MEAN72's Avatar
MEAN72
I had a similar problem of burning the wires against the header and finally went to a ceramic boot spark plug wire by Jacob Electronics. These can be ordered from JEGS or directly from Jacob's. A set will cost around $150. Maybe you only need one or two wires?
Old Jun 13, 2006 | 09:16 PM
Berserker78
What kind of headers do you have with your sidepipes?
Old Jun 14, 2006 | 05:29 AM
guppie's Avatar
guppie
St. Jude Donor '08
I too have true duals now, along with an Edelbrock performer polished intake and a 14064 Edelbrock carb, March underdrive pulley system, and 3:08 gears (yuck).
I guess the best way to desribe the results would be. I don't need gravel now to break the tires loose
Old Jun 14, 2006 | 03:05 PM
MEAN72's Avatar
MEAN72
Hookers on a BB. Would burn #1 plug wire
Old Jun 14, 2006 | 03:30 PM
js292's Avatar
js292
Here's another type for you if you have a small block,
http://www.stans-headers.com/Photos/109Y.jpg
Old Jun 14, 2006 | 03:33 PM
Berserker78
I do have a small block.
Is there an advantage to the 4-2-1 design over the 4-1?
Old Jun 14, 2006 | 04:04 PM
OldSchool's Avatar
OldSchool
I used the ceramic coated Dynomax. Look great, sound great, easy install, inexpensive. Checkout my pictures for them on the motor on a stand..
Steve
Old Jun 14, 2006 | 04:46 PM
rick1500's Avatar
rick1500
Steve
I thought I was going to buy some headers last week, but I still haven't made up my mind...
How do the ceramic Dynomax compare to the ceramic FlowTech?
DynoMax at Summit
FlowTech at Summit
The enlarged pictures of both of them on Summit's site shows them looking almost exactly the same. They both come with gaskets, reducers, etc. and both have the same pipe and flange thickness, but the FlowTech's are $50 cheaper. Is there a reason to get the Dynomax for the extra $?
Old Jun 14, 2006 | 09:23 PM
bertmeister's Avatar
bertmeister
I have the Stan's headers. Perfect fit, tuck up nice and tight underneath. Fits with angle plugs and has a 3/8" flange. A little pricey but probably worth it.
Old Jun 14, 2006 | 09:27 PM
norvalwilhelm's Avatar
norvalwilhelm
Any and all spark plug wire problems can be handled with ceramic spark plug extenders. I had 3 problem tubes, tried the Jacob's ceramic boots and finally tried the extender. They really solved all my plug wire problems.
These really work
http://www.wrenchrat.com
Old Jun 15, 2006 | 03:19 PM
MEAN72's Avatar
MEAN72
These really work
Wow! Those look great, better then Jacob's ceramic boots. I wish I had known about them earlier.
Old Jun 15, 2006 | 06:17 PM
Berserker78
Are those prices per each or for a set? It looks like per each from the way it is described. They are cool, but not $240 cool.
Old Jun 15, 2006 | 06:23 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
I'm using Hedman Hedders and had to clearance the right side tube for the idler arm to work ... easy enough to do.
Yep figure on using shorty spark plugs no matter what headers you use.
Old Jun 15, 2006 | 07:13 PM
Berserker78
Clearance = Pound a dent in?
To Header questions
Old Jun 15, 2006 | 07:17 PM
77vettejeff's Avatar
77vettejeff
I used block hugger shortys on my '77 w/SB. I made a pipe to go from the headers to my side pipes. I have no clearance probs with steering components or plug wires.
Old Jun 16, 2006 | 02:41 AM
rick1500's Avatar
rick1500
I'm thinking of getting Hedman's, but not if I have to "clearance" them right outta the box... Were they Hedman Elite's? BB or SB?
Old Jun 16, 2006 | 07:06 AM
D87's Avatar
D87
5th Gear
Default Headers
Flow Tech On My 80 With Fast Burn Heads
No Clearance Issues
Nop Spark Plug Problems
