Who has built Hydroboost lines?
Neal
Neal
6174808 PWR STR ADAPTOR #6 TO 18mm $7.95 $7.95
6172042 90° STEEL HOSE END, #6 $7.95 $23.85
6172040 STRAIGHT STEEL HOSE END, #6 $4.95 $4.95
6174031 O. 7/16"-24 IFM TO AN#4 MALE, BRK FIT $6.95 $6.95
6172018 90° STEEL HOSE END, #4 $7.95 $7.95
6173070 #4 BRAIDED HOSE, I.D. 3/16" $4.95 $4.95
6173261 #6 BRAIDED HOSE-6 FT, I.D. 11/32" $38.95 $38.95
6176176 FLARE REDUCER, AN4-6 $4.95 $4.95
Here is the list of about 90% of what you will need, I do not know the size and type of fitting for the stock P/S pump pressure side so that fitting is not included. The return line is not included either, on the return line all you will need to do is tee into the return line from the P/S cylinder with the return line from the HB, you can pickup these fitting from the local parts house. I used AN fittings on mine for the return line just for looks but it will add extra expense. If you would like the list of fittings for the return line I can supply it to. I purchased my parts from speedway motors. The lengths will vary depending on your setup the metric adapters are for the HB inlet (18mm) and outlet (16mm) the 7/16” x 24 x 4an is the adapter you will use for the inlet to the steering valve. They don’t make this fitting in 6an so you have to use 4an and than step-up to 6an. Fluid leaves the pump and enters the HB at the larger metric fitting, it then leaves the HB through the small metric fitting and goes through the 4an to 6an reducer on to the steering valve inlet. The third port on the HB is the hose barb; this is the return line. These are all high-pressure fittings and the hose is Teflon lined, the specs indicate it will handle 3000 PSI. The 6an 90* hose ends are for at the HB and at the back of the P/S pump, the 6an straight hose end is for the transition to 4an, the straight 4an, the 4an SS hose and the 4an 90* hose end are for the supply line from the HB to the P/S valve. Man I am confused now, hope this helps you out.
Neal
Neal
one of them is about 4" too long, but that's ok, works fine....
the lines were cut and ends changed in two spots, one for the pump output, but that had been that way for some 11 years allready...using a 3/8 brass compression coupling from Hdespot plumbing dept....so I did it again to shorten the steel line near the HB unit, both work fine...
GENE
btw, thats a really nice stingray
Exactly what this forum is all about!
