Is This Engine Corvette Compatible?
Old Aug 29, 2001 | 07:13 PM
Jon561's Avatar
Jon561
Default Is This Engine Corvette Compatible?
Hey everyone, I was wondering if this engine combination was Corvette compatible - would it fit under the hood of a '75 without any modifications or is too big? Here it is....
GM Performance Parts 502ci block
10:1 compression ratio
Dart 320cc rectangle-port heads
119cc combustion chamber
Comp Cams mechanical roller
260/268 degrees duration @ 0.050 tappet lift
0.714-/0.714-inch valve lift
108-degree lobe separation angle
Dart rectangle port, single-plane intake
Holley 1,050-cfm Dominator carburetor
2-inch headers
MSD 6AL CD ignition
This combo is said to produce 605 lb-ft/torque at 5,000 RPM and 664 hp at 6,500 RPM!!! I would love to have this engine in my 'vette!
Does anyone know if this would fit? Any comments about this engine? Thanks! :chevy
Old Aug 29, 2001 | 07:18 PM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
Default Re: Is This Engine Corvette Compatible? (Jon561)
It'll make the shark what it always should have been. Yes it'll fit, but you might want a taller hood with fresh air to the carb. :chevy
Dave
Old Aug 29, 2001 | 07:29 PM
Jon561's Avatar
Jon561
Default Re: Is This Engine Corvette Compatible? (Rolling Thunder)
Any suggestions for a taller hood?
Old Aug 29, 2001 | 07:56 PM
Ganey's Avatar
Ganey
Jon
Good fit, check dr. side valve cover to PB booster. Get L-88 hood for 73 up.
:cool:
Old Aug 29, 2001 | 09:26 PM
Indynut's Avatar
Indynut
Hey Jon,
Are you buying that engine in Canada? Can I be so nosey to ask what that set-up will cost in Canadian dollars. Man, it sounds like a wicked package! One anyone would just love to have under the hood of their shark. I'm soooooo jealous! :chevy :chevy :chevy :chevy :chevy :chevy :chevy
Old Aug 29, 2001 | 09:33 PM
Rods77's Avatar
Rods77
Won't the front suspension need to be beefed up due to the extra weight??
.....and yes I am green with envy. :cool:
Old Aug 29, 2001 | 10:07 PM
2nspire's Avatar
2nspire
Default Re: Is This Engine Corvette Compatible? (Rods77)
I gotta cut a hole in my hood. :( But with the hole in there hmmmmmm I wouldn't have to cut a much bigger hole for a, say, Blower. yeah :D
Old Aug 30, 2001 | 12:20 AM
MassVette's Avatar
MassVette
Works for me and Rolling Thunder--L-88 hood will even fit a hi-rise intake on that bad boy. :yesnod: :chevy :yesnod:
To Is This Engine Corvette Compatible?
