Correct Name for part?
Old Jun 20, 2006 | 10:36 AM
ESU's Avatar
ESU
Default Correct Name for part?
I need the correct name for the following part so I can locate it and order one. It's a solenoid type device that attaches to the side of my quadrajet and I believe it's supposed to engage when the a/c is turned on raise the idle a few rpms. I've seen some items called idle stop solenoids, is this the same animal? If so not many of the aftermarket houses have them, only place I found was corvette central, any locations to purchase this appreciated,
Thx, ESU
Old Jun 20, 2006 | 10:56 AM
chevylit's Avatar
chevylit
In the past I have found them at the local parts houses. The solenoid
was used on many different cars and shouldnt be hard to find.
Old Jun 20, 2006 | 11:04 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ESU
...I've seen some items called idle stop solenoids, is this the same animal?...
Yep, I believe so.
To Correct Name for part?
