"Special length" pushrods for TFS heads?
Old Jun 22, 2006 | 05:23 PM
72Shark's Avatar
72Shark
Default "Special length" pushrods for TFS heads?
I'm considering a cam swap in my '72, which is equipped with Trick Flow heads. I'm installing all new parts, including the pushrods. I was reviewing the Trick Flow information and it mentions "special length" pushrods are required. Does anyone know what length pushrod should be used? I thought about measuring one of the old ones, but who knows if the old one's are the right ones! Advice?
Old Jun 22, 2006 | 05:45 PM
zwede's Avatar
zwede
Don't trust any published info! You need to verify valvetrain geometry and select pushrods for your particular engine. You will need a pushrod checker.
Old Jun 22, 2006 | 05:49 PM
jeckel's Avatar
jeckel
Normally on a stock cam TF heads use a push rod length of +.100 over stock. If you are doing a cam swap as well as new heads, you should measure for the true correct pushrod length imo. You really need to pick up an adjustable push rod to measure correctly. One like this :
http://store.summitracing.com/partde...5&autoview=sku
Just my oppinion though.
Old Jun 22, 2006 | 07:57 PM
C3 Stroker's Avatar
C3 Stroker
...You should check length, but FYI on my TF heads, the +.100 over stock worked perfectly.
To "Special length" pushrods for TFS heads?
