tach cable replacement
Old Jul 6, 2006 | 03:04 AM
GM73VETTE's Avatar
GM73VETTE
Default tach cable replacement
My 1973 vette, need the tachometer cable replaced. does anyone have first hand info on replacement?
gm73vette
Old Jul 6, 2006 | 10:28 AM
682XLR8's Avatar
682XLR8
Buy a GM cable. The local Vette parts place had one for $50.
I had originally bought an aftermarket one from Corvette Central. Within about an hours run time, the cable self-destructed, wound itself into a loop, and that was with the distributor clocked to take the sharp curve out of the cable when installed
Hope I've helped
Old Jul 6, 2006 | 08:35 PM
GM73VETTE's Avatar
GM73VETTE
Thanks a lot.
I just purchased a cable from Corvette Central. Will try to return it and get a GM cable.
Did you have any trouble replacing the cable?
How did you get to the back of the Tach for connecting the cable?
gm73vette
Old Jul 6, 2006 | 08:46 PM
Garson's Avatar
Garson
Make sure it is the same length, The ones from the Corvette shops are to long( one size fits all) I had a speedo and tranny shop make one to the correct length.
Old Jul 6, 2006 | 09:02 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Connecting the cable to the back of the tach is difficult. It helps to have small hands.
Concerning the the point of location where the cable connects to the distributor, it helps to use a 90 degree fitting to reduce the chance of cable "kink".
Old Jul 7, 2006 | 12:20 AM
682XLR8's Avatar
682XLR8
Originally Posted by GM73VETTE
Thanks a lot.
gm73vette
Sorry it took so long to get back. Replacing the cable was a lot easier than I thought it would be, just reached up behind the dash(using the Braille method) and unscrewed it, and pulled it out from the firewall(after removing the rubber grommet first). Put it back in the same way, wasn't really as hard as it sounds.
The new one was in a GM wrapper and fit fine no trouble with it yet!
Old Jul 10, 2006 | 06:14 AM
GM73VETTE's Avatar
GM73VETTE
Used the Braille approach and got lost.
I stood on my head, used a mirror and flash light and could not see anything that looked close to a tach cable.
Do i have to remove instr panel and go thru the front?
Was your a 73?
Old Jul 10, 2006 | 07:31 AM
Fevre's Avatar
Fevre
73 snaps into the tach, there is a tab you need to push down on to get it out but it snaps back in pretty easy, real pain in the arz to be sure
Old Jul 10, 2006 | 12:53 PM
682XLR8's Avatar
682XLR8
Was your a 73?
Mine is a 68, the fact it does not have air-con might make a difference(ducting in the way?). I couldn't see the cable either, just had to feel for it, but I have had the dash out before and knew pretty much where to start.
Reach your hand up behind the tach, you should be able to feel the cable. Follow it to the rear of the tach. You should feel a small tab(mine has a screw-on fitting). Now push the tab with your thumb while gently pulling on the cable with your hand, and the cable should come out. It sounds over-simplified, and it's a hassle, but it can be done.
Were you able to find a GM cable?
Old Jul 11, 2006 | 02:57 AM
GM73VETTE's Avatar
GM73VETTE
Thanks for the tip.
I will try again the first thing in the morn.
gm73vtte
Old Jul 14, 2006 | 06:36 AM
GM73VETTE's Avatar
GM73VETTE
Found a cable.
Tried again. My ride has air conditioning and i think that the air duct is in my way and need to remove the insrument panel cover and duct.
Thanks again for the advice.
gm73vette
To tach cable replacement
