Model Differences 68-70
Old Jul 8, 2006 | 11:51 PM
KrytDrgn's Avatar
KrytDrgn
Default Model Differences 68-70
What are the primary differences between these models? Ive seen advertisement for 70 models with flip lights and without like these:
http://cgi.ebay.com/ebaymotors/S-MAT...ayphotohosting
I'm looking into buying one in the future and wanted to know the differences between these years.
Old Jul 9, 2006 | 12:07 AM
MRANT212's Avatar
MRANT212
68 had some cooling and build quality issues. 327 motor was also the starting small block. different type door handles..pushbutton outside
69 was much improved. Flush door handles Small block was 350 to start. All types of 427's available
70 wheel wells were flared out to prevent chips from rocks etc. Box tips on the exhaust vs round tips on 68/69. Side gills now have a criscross pattern. Interior improvments and big block grew to 454. &0 was a short build year due to the GM strike so there were fewer cars built
71 was very similar style except hrsepower ratings dropped a bit due to lower compression ratios to accomodate unleaded fuel. Last yr for fiberoptics.
Hope this helps!!!!
Anthony
Old Jul 9, 2006 | 12:14 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
'68: 7 inch wide Rallye wheels
'69 - '70: 8 inch wide Rally wheels
'68: 4 tail lights/brake lights and backup lights below rear bumpers
'69 - '70: 2 tail/brake lights and 2 backup lights in the same location as the inner tail/brake lights on '68 model
'68: push button door *****
'69: door would open with handle - no push button
'68: no map pocket on dash
'69 - '70: map pocket on passenger side dash
'68: headrests were optional, so most '68 Vettes don't have headrests
'69: headrests were standard. Other than the headrests, '69 seats were basically the same as '68 seats
'70: seats changed to integrated headrest seats
'68: shifter console had the crossed flag and no sticker with performance data
'69 - '70: performance data and engine option on shifter console
'68 - '69: 4 front side vents (3 of them functional). Vent inserts were optional for '69 but not '68
'68: no Stingray emblem
'69 - '70: Stingray emblem
'70: egg crate side grill
'68: Front grille was aluminum with round blinker
'69: Front grille was plastic with round blinker
'70: Front grille was aluminum with square blinker
'68 - '69: small side marker lamps
'70: larger side marker lamps
'68: small blocks were 327's
'69 - '70: small blocks were 350's
'68: ZL-1 option not available, LT-1 option not available
'69: ZL-1 option available - only 2 vehicles known to exist right now with that option, LT-1 option not available
'70: ZL-1 option not availbable, LT-1 option available (370 HP solid lifter 350 small block)
'68: front wheel bearings smaller
'69 - '70: Front wheel bearings larger
'68: approx. 28 inch wide radiator
'69 - '70: approx. 31 inch wide radiator
'68: no tilt steering column available
'69 - '70: tilt steering column available
'68: 18 inch steering wheel - wood look
'69 - '70: 16 inch black steering wheel
'68, '69 and '70 had each different door panels
'68 - '69: no wheel well flares
'70: wheel well flares
'68 - '69: Big Blocks were 427's
'70: Big Blocks were 454 and therefore, all engine codes for big blocks were changed
'68 and '70: Side Exhaust NOT available
'69: Side Exhaust was an available option
I know that there are a lot more differences, but I can't think of them at the moment..
Old Jul 9, 2006 | 12:26 AM
crazywelder's Avatar
crazywelder
GranSport your good!
'68 last year for wood grain steering wheel and it was about an inch larger in diameter.
'68 door trim panels were one year only. They were thicker at the top than '69 and later and they make the interior feel smaller.
'68 front marker lights were clear, '69 were amber.
Old Jul 9, 2006 | 12:37 AM
GrandSportC3
I got the steering wheel already
They were 18 inch in '68 (wood-like) and 16 inch thereafter.. (until '75)
Door panels were different each year from '68 - '70
Missed the color thing on the side marker lamps! Good catch!
Old Jul 9, 2006 | 08:08 AM
vettepilot68's Avatar
vettepilot68
I think the 68 steering wheel is 16*, not 18 and all others are 15".
Old Jul 9, 2006 | 01:11 PM
KrytDrgn's Avatar
KrytDrgn
Thanks guys, I really appreciate it. Helps out a lot in making my decision. Check out the headlights on the car below. I haven't seen anything like that so far on other models of the same year. Is that like a kit you can do to it or a factory option or something?
http://cgi.ebay.com/ebaymotors/Chevr...QQcmdZViewItem
eBay Motors: Chevrolet : Corvette (item 150005576124 end time Jul-08-06 10:30:59 PDT)
Old Jul 9, 2006 | 01:42 PM
Z-man's Avatar
Z-man
It's an aftermarket kit of some kind...
Old Jul 9, 2006 | 01:51 PM
GrandSportC3
you are right.. Just measured!!
Old Jul 9, 2006 | 01:53 PM
GrandSportC3
Just thought about another difference.
'68 headlamp bezels were metal. Don't know about '69 but I believe that they were fiberglass in '70
Old Jul 9, 2006 | 02:01 PM
PRNDL's Avatar
PRNDL
Wow, that's a high mileage vette!
And the first auction, the 69 vette, note that it has the 70-72 style rocker mouldings, not the black/silver ones used in 68/69.
To Model Differences 68-70
