tube bending
Old Sep 1, 2001 | 09:45 PM
Turbo-Jet's Avatar
Turbo-Jet
Default tube bending
is there a trick to this, or am i using a crappy bender?
i am trying to bend 3/8" fuel line but this bender i am using kinks the tube on bends greater than ~30deg. i think it is because the mandrel part is made of plastic, which defects and does not contain the tube.
any reccomendations on tube benders? what features should i look for?
thanks.
[Modified by Turbo-Jet, 5:46 PM 9/1/2001]
Old Sep 1, 2001 | 11:55 PM
RJR99SS's Avatar
RJR99SS
Default Re: tube bending (Turbo-Jet)
could be you're just using a cheap bender. one trick i've heard of is filling the tube with sand to prevent kinking, but i've never done it myself. of course you have to make sure to get ALL of the sand out afterwards...
Old Sep 1, 2001 | 11:58 PM
john73bb's Avatar
john73bb
Make sure the tube fits just perfectly into the mandrel part of the bender. If it is too big (or too small even) you will likely kink it. I have bent 1/4" and 5/16" steel brake line with a decent bender and it worked great. The bender I used had a metal (aluminum) mandrel, though I dont' think it should matter if it is metal or plastic.
Old Sep 2, 2001 | 12:16 AM
RMS73's Avatar
RMS73
Are benders the correct type/size. The benders that I have are for a specific tubing OD. That is you use a 3/8 bender for 3/8" OD tubing. If you use 3/8 tubing in a 1/2" bender the tubing will knik.
Roger
Old Sep 2, 2001 | 12:17 AM
redvetracr's Avatar
redvetracr
turbo,
I just had to replace three fuel lines and one brake line on an`89 Buick ALL front to back!, try to start the bend early and move the tubing in the bender as you go,bending a little at a time. NOT as easy as it should be BUT take your time and you`ll get it. The big (3/8) stuff is of course more difficult than brake line. ...redvetracr
Old Sep 2, 2001 | 06:12 AM
Dalannex's Avatar
Dalannex
http://www.basicmachinetoolsofarkans...ers/eaton.html
I used to be the Plant Manager at a factory where we bent tubing for agricultural and automotive industries. This is the bending machine I did all of my lines for my 81 on. Of course, with a price tag of up to $250,000 I don't think we can all afford one of these, not to mention 13 of them like we had, but it sure does make the job nice. :D In all reality, though, I don't like hand operated tubing benders with plastic dies because the dies tend to slip and compress. I have bent using a number of all steel hand benders and as long as the bender is the right size for the tube and the radius isn't too small it works fine. For 3/8" tubing I would use a bender made for 3/8" tubing with a radius of 1" or larger. 1.25" radius would be nice. That will get you into pretty tight place without much chance of kinking. Good Luck.
Old Sep 2, 2001 | 08:38 AM
Larry B.'s Avatar
Larry B.
Default Re: tube bending (Dalannex)
Parker Hanafin (sp) makes a good hand bender for small tubing up to 1/2". There is a different bender for each size. There a a learning curve as to how to bend tubing but it is easy once you seee how it works. Kinking is not a problem, getting the bends in the right place IS what's hard to do. Get can a book with the bender that shows you how to bend accurately .
Old Sep 5, 2001 | 03:41 PM
Turbo-Jet's Avatar
Turbo-Jet
Default Re: tube bending (silvervetteman)
what a difference a good tool makes! the plastic-mandrel, lead-screw bender was a POS. i borrowed a steel lever-style bender and used a little grease on the mandrel and die. results: perfect bends, with good control of bend angle.
thanks!
[Modified by Turbo-Jet, 11:41 AM 9/5/2001]
To tube bending
