Mark VIII Fan
Old Jul 16, 2006 | 09:38 AM
  #41
Fevre's Avatar
Fevre
That is a lot of amps for the stock alt wiring
Old Jul 16, 2006 | 11:54 AM
  #42
BerniesVette's Avatar
BerniesVette
Thanks to PhotoVette1 providing the necessary sources to research this fan, I found that a 130 amp alternator is needed for this modification. A Delta Current Controller looks to be a wise investment as well. I am still reading all the info provided and am convinced that, installed correctly, this setup will provide more than adequate cooling for any requirement one might have. Although I don't really have any cooling issues right now, I am collecting these parts to upgrade when I pull the engine this winter.
Bernie
Old Jul 16, 2006 | 01:10 PM
  #43
rastadr's Avatar
rastadr
where do you buy a 130 amp alt?
Old Jul 16, 2006 | 01:40 PM
  #44
PhotoVette1's Avatar
PhotoVette1
Bernie
I ordered the Delta controller Friday--I'll give it a good test and provide results with video shortly.
Old Jul 16, 2006 | 02:22 PM
  #45
BerniesVette
PhotoVette1,
Post as much installation info and pics as possible, electronics is a very weak part of my mechanical ability. I was reading the info on the mustang install and it seems that he used 2, 75 amp relays. I have the Mark VIII fan purchased and will look for a 130 amp alt next. I think they were used on chevy trucks and I know hotrod suppliers have them. I would rather have a 3 wire alt than a 1 wire if possible. Thanks again for the help!
Bernie
Old Jul 16, 2006 | 04:26 PM
  #46
Capt. Ron's Avatar
Capt. Ron
I would be interested in knowing what type of highway temps (60MPH +) you were running before and after installation. I have another thread running close to this subject (Aux cooling fans) and am watching this thread carefully.
Capt. Ron
Old Jul 16, 2006 | 04:52 PM
  #47
mrtroutjedi's Avatar
mrtroutjedi
I got it from a guy on ebay
http://stores.ebay.com/Alterstart_W0...Q3amesstQQtZkm
there his online store Ive had no problems with it I have had it installed for over a year and it works fine.
Old Jul 16, 2006 | 06:01 PM
  #48
PhotoVette1
Capt. Ron
Highway temps are the reason I am trying this. With the stock fan/clutch, I had no problems in town--on the highway however, it climbed to 230+ after awhile. The thermal clutch would disengage fully and never come back on at speeds over 65 mph. I am pulling 3000 rpm at 70 mph.
The ideal solution would be an overdrive transmission, but I went this way. Of course, with the price of gas about to go out-of-sight, I still my put an OD transmission in.
I ordered the pulse width controller and this circuit breaker to handle the load:
This has become a real project; I pulled the radiator core and am changing that. Then I decided that it is a great time to change the condenser coil and refrigerant lines. Of course, I gotta sand and re-paint the engine compartment walls now.
I will certainly have Corvette withdrawl syptoms before its back on the road again...
Old Jul 16, 2006 | 06:47 PM
  #49
BerniesVette
I noticed at least a ten degree drop in temp when I installed my manual 5 speed at 70 mph. I was running 3200 rpm at 70 now I'm running 2100 rpm. The best mod I have done to make the car more enjoyable, fun and with less heat!
Bernie
Old Jul 16, 2006 | 08:42 PM
  #50
mrtroutjedi
where did ya get the pulse thingy?
Old Jul 16, 2006 | 08:58 PM
  #51
Capt. Ron's Avatar
Capt. Ron
Hey PhotoVette1, Did you ever sail out of Kings Bay?? Check my avatar, I may have sent you to sea and brought you back. I've been doing this since the early 80's.
Capt. Ron
Old Jul 17, 2006 | 07:29 AM
  #52
BerniesVette
Capt. Ron,
You might be asking him a question he isn't at liberty to answer.
Bernie
Old Jul 17, 2006 | 07:35 AM
  #53
Capt. Ron's Avatar
Capt. Ron
Yea, quite possible. He might have to "kill" me if he told me!
Old Jul 17, 2006 | 11:51 AM
  #54
PhotoVette1
Capt. Ron
Never made it to Kings Bay--was out of Holy Loch Scotland for the most part--then Charleston.
Besides, we never had to be towed out--just towed in from time to time.
Hey! I was on Deck Division on a Fleet Tug (USS Paiute ATF-159) out of Mayport for a year before I went to nuke school. You need any crew? These darn models are killing me and I'm ready for a change of career! That was real Navy--I should have stayed aboard her.
I'm a lot better trained now then I when I served aboard her--diesel tech (8 1/8)--plus every school a Nuke MM could get--off crew periods were great for training.
Old Jul 17, 2006 | 11:53 AM
  #55
PhotoVette1
I got it here--http://www.dccontrol.com/ --still in the mail--I have not tested it yet.
Old Jul 17, 2006 | 12:19 PM
  #56
Capt. Ron's Avatar
Capt. Ron
My company is looking for licensed captains and licensed engineers every day to work in the Gulf of Mexico and paying big bucks!
Old Jul 21, 2006 | 04:34 PM
  #57
mrtroutjedi
well i tryed to install the other day and the fan was hitting the sway bar and i couldn't cut off enought to make it fit without the fan hitting the rad so I have rethink it (maybe im just dumb) hmmmmmm
Old Aug 3, 2006 | 02:20 AM
  #58
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Here: I made it easier to see... Great Install Job!
Where'd you get the cool circuit breaker thingy?
