Headlight actuator
Old Jul 14, 2006 | 02:11 PM
hurricanejames's Avatar
hurricanejames
Default Headlight actuator
I have an '82 that recently incurred a headlight malfunction. Lifting the hood revealed a vacuum line coming from the headlight to (I'm thinking) the actuator, but the line had a broken piece of material in the end of it and it was just hanging there. It had apparently broken off at some point. My question is, if any of you have had the same problem, and if so, what needs replaced? Can I just replace that piece, or do I need the complete actuator? Thanks in advance...
Old Jul 14, 2006 | 02:23 PM
SIXFOOTER's Avatar
SIXFOOTER
it probably broke off the relay. so that will be what needs fix/replacing. There is a good paper on this at corvette faq
Old Jul 14, 2006 | 06:03 PM
76vette1's Avatar
76vette1
It is probably from your relay valve. Some of the repro valves are just as bad. They break with a minimum of effort. There is one repro valve that comes with the vacuum hose color coding on them that has held up much better. Unfortunately, I don't know who has them.
Old Jul 15, 2006 | 07:31 AM
hurricanejames
Hey guys...Thanks for pointing me in the right direction....Much appreciated.
To Headlight actuator
