From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Originally Posted by 68 NJConv 454
Right, 3" diameter over the stock 2.5" but whats the difference b/w ordering the HD ones that you ordered or just ordering a mid 80's half shaft? I'm hoping that the HD ones you ordered have thicker walls or reinforced mojo. Will a stock late C3 half shaft bolt right into a 68 or 69 without mods?
I ask b/c early next week I too will be ordering 3" half shafts for my 68 and keep the stock 2.5" as spares.
Fort Wayne Clutch has them for $150 a pair w/flange and w/spicer u-joints. You paid that for one, so I'm assuming your HD's are stronger.
Another stupid question after the above one is given thought, did 68 big block cars come with 2.5" halfshafts or larger 3" ones? I thought the 3" did come around till early 70's...
Nothing special other than shaft Dia, same as big block
wish i knew about ft wayne clutch, the higher price just comes from dealing with ecklers, and i needed it now, so i paid more.
but yes big block cars had the larger ones even back then, and even some small block depending on what gears you rdered
Yeah but I bet Ft. Wayne Clutch's half shafts don't look as pretty as ecklers mirror finish.
So is it safe to say that if you see a 68 or 69 with original 2.5" half shafts then the car was originally a small block car???
yes that is a safe statement, borrowoing the exceptions from the factory, or customer orders, I know a guy whose car was a small block car but origionally came with the 3" half shafts associated with a gearing selection, 38 years ago all kinds of oddities and mix matches occured
Update
I must go get some clear coat for these suckers
any suggestion team ?
ROCHESTER, NY, US 07/27/2006 2:41 A.M. OUT FOR DELIVERY
07/27/2006 2:39 A.M. ARRIVAL SCAN
If clearing them, clean very well with lacquer thinner or isopropyl alcohol.
I prefer Krylon for my spray painted parts ... fast dry and no drips.
Be careful not to get solvent on the Ujoint seals.
Ok
how about a polyeurothane clear coat?? Ive used it on things like hinges and such, but never on something outside of the engine bay
I have the Fort Wayne half shafts and so does another Forum member, they are very heavy duty with spicer solid u joints and came with the mirror finish also. Wouldn't be surprised if they supplied Ecklers with the shafts....
Sign me up, calling them Monday!!!
Sweethence, pics of your new halfshafts??? I need to build up some saliva, OJ in the morning gives me cotton mouth.
Ok team here you go, these things are sweeeeet, and well built too, nice welds all the way around, a quality piece, ill have to call ecklers and see if Fort Wayne did indeed make these
oh and passed a c4 with two littel old ladies in it on the way home
Those look great. Lot of nice new goodies, too.
I guess polyurethane would work OK, but it dries very slowly
and has a tendency to drip.
Me tinks that's a C4 vert.
