Trick for oil changes....
Old Jul 25, 2006 | 04:06 PM
bwellisley's Avatar
bwellisley
Default Trick for oil changes....
A co-worker just told me a small trick for oil changes, maybe some of you do this already...?
He noted that when you change your oil and filter you should fill the filter 3/4 full with oil prior to installation, along with lubricating the seal which I have always done. Being in a family entirely automotive based with GM I had never heard this as a step. He noted that by doing this you may prevent dry cycling of the engine between the time it takes to pump up the oil pressure to get the oil into and out of the new oil filter.
Just found this as interesting/useful information...
Anyone else do this? Could be an extra step to baby that fine-tuned Corvette motor!
Old Jul 25, 2006 | 04:12 PM
PRNDL's Avatar
PRNDL
SOP.... Just don't try it with the newer vehicles where the frigging filter goes on upside down!!
zwede's Avatar
zwede
Yep. I've always filled the filter befor einstalling. I thought everyone did that? If you don't you'd run the engine with no oil pressure for several seconds.
Old Jul 25, 2006 | 04:33 PM
mandm1200's Avatar
mandm1200
I always fill mine up. As a teenager I worked in a garage and that's the way they did it.
Old Jul 25, 2006 | 04:38 PM
knbwag73's Avatar
knbwag73
Yes, been doin that for a very long time, only way to go!
Old Jul 25, 2006 | 04:45 PM
1Z87L8's Avatar
1Z87L8
been doing it that way since pop taught me back in the 70s
and another trick is a simple disk magnet on the bottom of the filter
to trap and metal particles and keep them in the filter.
Old Jul 25, 2006 | 05:33 PM
MartyW's Avatar
MartyW
They sell magnetic oil drain plugs for the same reason to pull out and trap the metal particles.
Old Jul 25, 2006 | 05:43 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Good tip. I use it on my Chevys. Just don't try it on an import. You will be wearing the oil.
Old Jul 25, 2006 | 05:44 PM
Mark PittPayne's Avatar
Mark PittPayne
There have been past threads on this issue and it came down to a matter of personal preference. Your engine maintains enough lubricant that it is not going to get damaged. I do fill mine on the vette because it means less topping up at the other end, ( and fact or not I feel I get a better filter seal). Like PRNDL stated, there is no way I would try that on my daily drivers that have the filters on sideways.
Old Jul 25, 2006 | 05:53 PM
427-390's Avatar
427-390
One tip I learned when removing an old oil filter from the car when changing the oil; use a plastic grocery bag to put around the oil filter when you are just about done unscrewing it from the engine. This will prevent oil from spilling down your arm or on the floor. You can then encapsulate it in the plastic bag. Very neat and usually not too messy.
Old Jul 25, 2006 | 06:20 PM
wagonerjim's Avatar
wagonerjim
Excellent tip. I've been changing oil for years and never thought of it. Of course I'm not an experience mechanic who probably already knew this tip.
So thanks for the information.
Old Jul 25, 2006 | 06:34 PM
wnmech's Avatar
wnmech
I go one step further when I change my oil and filter besides prefilling the filter I disconnect the ignition sourse from the distributor and motor the engine until I get oil pressure indicated on my gauge. I am sure you all Probably thnk its dumb but Knock on wood I have never had and engine failure.
Old Jul 25, 2006 | 08:26 PM
VCuomo's Avatar
VCuomo
Completely fill the filter - not 3/4 full!
Old Jul 25, 2006 | 08:46 PM
Nemesis_152's Avatar
Nemesis_152
i do it, but i dont really put any stock in an increase in protection.
Old Jul 25, 2006 | 08:57 PM
JoeRags's Avatar
JoeRags
the only reason I dont go to jiffy lube or other places.... i fear them not filling the filter.
Old Jul 25, 2006 | 09:27 PM
TPL79's Avatar
TPL79
You may have to wait a few seconds when the oil gets to the top as it absorbs into the filter element. Just simply top it off a few times then she's full.
Old Jul 25, 2006 | 09:36 PM
68 NJConv 454's Avatar
68 NJConv 454
Good tips, learn somthing new everyday. Will use the plastic bag and fill'er up from now on.
To Trick for oil changes....
Old Jul 25, 2006 | 09:46 PM
PRNDL's Avatar
PRNDL
That fear would not keep me away from Jiffy Lube. What keeps me away is that I fear them not filling the crankcase !!
Old Jul 25, 2006 | 10:17 PM
Eddie 70's Avatar
Eddie 70
I fear the Monkeys under the rack. I had some new tires put on my truck about a month ago. I think I could have done a better job at it than those tire jockeys. Same reason I try to do all of my own work.
Old Jul 25, 2006 | 10:32 PM
71 Green 454's Avatar
71 Green 454
I fear them not tightening the drain plug.
