drivers window wont roll down
Old Jul 28, 2006 | 12:19 AM
spille85's Avatar
spille85
Default drivers window wont roll down
Hey everyone, I went out today to work on my car and decided to roll the windows down. Well I hit both switches and only the passengers window went down. I tried the drivers side window, but nothing happens.....UPDATE: I took the plug that normally goes to the drivers switch and place it on the passengers switch...nothing happened, so I took the passenger plug and plugged into the drivers switch and it worked...so the switches are working...what now? Are they are seperate fuses? any suggestions....thanks marty
Old Jul 28, 2006 | 05:33 AM
Bob Onit's Avatar
Bob Onit
Can you see it pulling on the charging system when you hit the switch?
Old Jul 28, 2006 | 08:48 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the driver's side switch. It's used the most often and typically fails before the passenger's side. For a quick fix, swap the two.
To drivers window wont roll down
