Question regarding vacuum secondaries
Old Jul 30, 2006 | 03:33 PM
Vermel's Avatar
Vermel
Default Question regarding vacuum secondaries
When approx do vacuum secondaries kick in? Do you need WOT?
Running a 750 Holley
Chris
Old Jul 30, 2006 | 08:04 PM
bondoboy's Avatar
bondoboy
Holley sells a secondary spring kit to tune when they come in. I don't think you have to be wide open before they open, but I may be wrong.
Old Jul 30, 2006 | 08:21 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
Vacume secondairies work as described. They will normally only open at WOT under load. Which means if you are parked and open the carb fully the chance of the seconds opening is little to none. They will only open when the engine demands more air and fuel. You can put in lighter springs to make the seconds open sooner but be careful doing this as you do not want them opening too soon. If set correctly you will not even feel the seconds open as it will be a smooth transisiton.
Old Jul 30, 2006 | 10:37 PM
Vermel's Avatar
Vermel
So if I'm not getting WOT because my throttle cable needs adjustment no secondaries..huh.. I'm about 15-20 degrees of pitch off from WOT on the primaries..
I thought my secondaries weren't kicking in. I didn't feel that kick or here it scream.
Old Jul 31, 2006 | 01:28 AM
SHAKERATTLEROLL
You should have WOT on your Primaries so adjust the throttle cable so you have that. But the vacume part operates the secondaires. If you need more info give LARS here a shout and I am sure he can help you out with details.
To Question regarding vacuum secondaries
