Dash Cap Question
Old Aug 6, 2006 | 08:28 PM
Hybrid117's Avatar
Hybrid117
Default Dash Cap Question
Ok, i just bought my new dash cap for my 1980, it tells me to remove some ***** so i can fit it, i tryed to remove my headlight **** and i have no idea how to do it, any ideas?
Old Aug 6, 2006 | 10:42 PM
7T1vette's Avatar
7T1vette
To remove the headlamp switch ****, you have to do the following:
1. disconnect the battery pos. connector
2. pull the switch out to the ON position
3. reach up underneath the dash panel to the switch body
4. feel around for a spring-loaded button (about 1/4" diameter) and press it inward (toward the switch body)
5. remove the **** and shaft.
To reinstall it, simply put the shaft in the hole and push it in.
Old Aug 7, 2006 | 08:21 AM
EDDIEJ82's Avatar
EDDIEJ82
Also if you want to get the headlight switch out so that you can take off the bezel that says light on it, after you remove the **** it has a securing screw for the switch that has 2 indentions on it that you will have to take out. I just use needle nose pliers in the indentions and twist it out.
I'd like to see some pics of what it looks like after install. I thought about going this way but decided on going with tweed since the rest of my int was in pretty bad shape. Check out my threads: Cheap fix for a cracked dash and Cheap fix for a cracked dash part 2. Sorry dont know how to link them but you can use the search function
Old Aug 7, 2006 | 05:38 PM
Hybrid117's Avatar
Hybrid117
Thanks that did it! And ya i will post some pictures when its installed, im 18 and i have alot goin on so im not sure when i will get around to it.
Old Aug 7, 2006 | 05:43 PM
moosie982's Avatar
moosie982
http://forums.corvetteforum.com/show....php?t=1462368
copy and paste,,,,,,thats how, Peace,,,Moosie
Old Aug 7, 2006 | 07:53 PM
79vetter's Avatar
79vetter
I would be curious to see what you dash cap looks like after it is installed. There have been mixed opinions about those caps here on the forum. I bought one from Palco industries and when I dry fit it, it didn't seem to fit the wiper bezel very well. I eventually returned it because I got a good deal for a real dash here on the forum.
Post some pics when finished
Old Aug 7, 2006 | 08:13 PM
Carl914's Avatar
Carl914
A new $500 dash looks better, but my $99 cap sure looks 100 times better than my old cracked dash. It does take a tiny bit of trimming around the glove box and such, but I am okay with it. I left it right out-of-the-box black, I just hit it with a little bit of Armorial from time to time.
Thanks.
www.mycarframes.com
Old Aug 7, 2006 | 11:57 PM
1982CorvetteDude's Avatar
1982CorvetteDude
Thanks.
www.mycarframes.com
Was this supposed to be a link to your dash??? I can't seem to find it.
To Dash Cap Question
