HELP!!! Problem with a friends FORD
Old Aug 7, 2006 | 03:43 AM
sam74c3's Avatar
sam74c3
Default HELP!!! Problem with a friends FORD
FORD, where do I start? He brings me this 1999 3.0 v-6 ranger of his with a check engine light and a misfire code(po302). I changed the plugs, plug wires, coil, and crankshaft sensor. The engine is still missing on #2. The trucks got 100,000 miles on it. Anybody ever had a po302 code, and fixed it with something other than what Ive already done? Any ideas?
Old Aug 7, 2006 | 07:15 AM
jdmick's Avatar
jdmick
Try these guys:
http://www.batauto.com/cgi-bin/Forum/db_TalkToMeV2.cgi
You could also try googling the error code.
Old Aug 7, 2006 | 08:02 AM
mrtroutjedi's Avatar
mrtroutjedi
it could be a bad fuel injector no gas = misfire
Old Aug 7, 2006 | 08:11 AM
sam74c3's Avatar
sam74c3
At the risk of sounding like a dummy.... how do you check injectors? I usually only deal in really old stuff.
Old Aug 7, 2006 | 08:58 AM
red79c3's Avatar
red79c3
You have to have the software to clear the code once you've completed the work or it will keep on showing up, even if the problem has been fixed......
Old Aug 7, 2006 | 09:27 AM
theandies's Avatar
theandies
If you really want to help your friend then tell him to sell that Ford.
Old Aug 7, 2006 | 09:34 AM
mrtroutjedi
i would unplug the injector and see if it runs the same if no change bad injector
Old Aug 7, 2006 | 10:00 AM
Jims79's Avatar
Jims79
Before you replace an injector on an old truck w/a 100K try filling the tank w/good gas & adding a pint of a "good" brand fuel injector cleaner like Gunk-Out. I had the same problem w/my daughters VW Bug & the stuff ready works. I forget the name of the stuff but it was in a black bottle and made by one of the major gas company's.
Old Aug 7, 2006 | 10:09 AM
sperkins's Avatar
sperkins
Any driveability problems?
Old Aug 7, 2006 | 10:26 AM
noonie's Avatar
noonie
You can take a stethoscope and put it on the injector and listen for clicking sounds. They should increase with rpm. You can also use a noid lite (cheap).
You cannot test if it sprays properly this way. You can rig up a pressurized apparatus to test, but for a 1 shot deal it probably is not worth it.
You can also use Chevron injector cleaner, the same as pros use, but they use it at very high concentrations to clean the system whilt running. Should be done regularily anyway for best performance
Old Aug 8, 2006 | 02:13 AM
sam74c3's Avatar
sam74c3
Originally Posted by jdmick
Try these guys:
Thanks for this website! I found something usefull, another guy with the same truck and problem. They tried everything I did, and it turns out that these 3.0 heads are bad about valve seat wear. They wear down so that the valve no longer seats, causing loss of compression and thus a misfire. My next test will be a compression test on #2.
Old Aug 8, 2006 | 02:19 AM
sam74c3's Avatar
sam74c3
I cleared the code each time. My manual said to clear it by pulling the NEG. battery cable for at least 30 seconds. It worked, but as soon as you take the truck down the road, and it starts running rough, the check engine light comes back.
Old Aug 8, 2006 | 02:21 AM
sam74c3's Avatar
sam74c3
Ive tried it, he uses B-12 CHEMTOOL injector cleaner every other fill-up.
Old Aug 8, 2006 | 06:06 AM
jdmick's Avatar
jdmick
To HELP!!! Problem with a friends FORD
